Component: DMX-512 Master (Comms: System)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Comms: System
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here for the component source code: FC_Comp_Source_DMX-512_Master_SCADA.fcsx
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
DMX Master Example1
For DMX 512 slave example see: DMX Slave
SetDataChannel
Sets the data byte in a data channel
- UINT Channel
- BYTE DataValue
SendDataChain
Transmits the BREAK, MAB and StartCode followed by the contents of the data channels.
- BYTE StartCode
Configures the UART serial interface.
Serial Properties
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
Timeout Value
Value to specify what is returned when no incoming receive data is present.
DMX Properties
Data Channels
Number of data bytes used by the DMX chain, Max 512 bytes per transmission. 24 Bytes minimum to match minimum 1204us timing requirements, not all channels need to be used.
