Component: Switch Array (Push) 2D (Switches)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Switches
Switch Array (Push) 2D component
An array of up to eight slide switches. In embedded mode each switch is connected to a single pin of the specified port.
Please click here for the component source code: FC_Comp_Source_Switch_Array_Push_2dgi.fcfx
Fc9-comp-macro.png ReadState
Read the state of the switch at the given index.
Fc9-u8-icon.png - BYTE Index
The switch to read the status of.
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the switch at the given index is turned on.
Index of the switch to wait for.
Fc9-comp-macro.png ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
Fc9-comp-macro.png WaitUntilLow
Fc9-conn-icon.png Switch Settings
Fc9-type-16-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-type-14-icon.png Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Fc9-type-16-icon.png Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Fc9-conn-icon.png Label
Allows you to add your own label to each switch. If Same as Handle is selected then all custom text will be erased.
Fc9-type-1-icon.png Label colour
Colour of the port and pin labels
Fc9-type-7-icon.png Show Connection Label
Enable or disable the pin values underneath each switch
Fc9-type-7-icon.png Show Pin Value
Enable or disable the pin level (GND or VCC) underneath each switch
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Switch layout
Fc9-type-21-icon.png Distance between switches
Set distance betwwn each switch. Default = 55
