Author
Matrix TSL
Version
2.0
Category
API Slave Devices
API (Arduino Mega) component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to view the component source code (Beta): FC_Comp_Source_Arduino_Mega_API_Comp.fcfx
I2CInitialise
- BYTE
- BYTE
Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
8-bit samples returned from the function
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
Outgoing data
- BYTE
DataIn
Incoming data
IOGetInputPin
- BYTE
Pin
Range: 0-53
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
ADCSample8
- BYTE
ADCChannel
Range: 0-15
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
Data variable to receive into
- UINT
Count
Number of bytes to receive
- UINT
UARTCheckRX
- BYTE
- BYTE
UARTInitialise
- BYTE
RegisterWrite
Writes to one of the registers on-board the device
- UINT
RegisterAddress
The address of the register
- BYTE
Data
The data value to assign to the register
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE
ChargeTime
Default 10
RegisterRead
Read one of the registers on-board the device
- UINT
RegisterAddress
- BYTE
I2CRestart
- BYTE
PWMDisable
Disable a PWM output
- BYTE
Range: 0-15
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
I2CStop
- BYTE
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE
RefType
0=AREF, 1=VCC, 3=Internal 1.1V
SPIPrescaler
- BYTE
- BYTE
Prescaler
Range: 0-2
PWMSetDuty
- BYTE
Range: 0-15
- BYTE
Duty
ADCSample10
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023
- BYTE
ADCChannel
Range: 0-15
- UINT
I2CTransSend
- BYTE
- BYTE
Data
Data to send
- UINT
Count
- UINT
IOSetOutputPin
- BYTE
Pin
Range: 0-53
- BOOL
State
Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
7-bit Device Address
- BYTE
Baud
SPIInitialise
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
PWMSetPrescaler
- BYTE
Range: 0-15
- BYTE
Prescaler
- BYTE
Period
Default 255
PWMEnable
Enable a PWM output
- BYTE
Range: 0-15
ADCSampleArray10
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
Outgoing data
- BYTE
DataIn
Incoming data
IOGetInputPin
- BYTE
Pin
Range: 0-53
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
ADCSample8
- BYTE
ADCChannel
Range: 0-15
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTCheckRX
- BYTE
- BYTE
UARTInitialise
- BYTE
RegisterWrite
- UINT
RegisterAddress
- BYTE
Data
ADCSetPrechargeTime
- BYTE
ChargeTime
Default 10
RegisterRead
- UINT
RegisterAddress
- BYTE
I2CRestart
- BYTE
PWMDisable
- BYTE
Range: 0-15
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
I2CStop
- BYTE
- BYTE
RefType
SPIPrescaler
- BYTE
- BYTE
Prescaler
Range: 0-2
PWMSetDuty
- BYTE
Range: 0-15
- BYTE
Duty
ADCSample10
- BYTE
ADCChannel
Range: 0-15
- UINT
I2CTransSend
- BYTE
- BYTE
Data
Data to send
- UINT
Count
- UINT
IOSetOutputPin
- BYTE
Pin
Range: 0-53
- BOOL
State
Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
SPIInitialise
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
PWMSetPrescaler
- BYTE
Range: 0-15
- BYTE
Prescaler
- BYTE
Period
Default 255
PWMEnable
Enable a PWM output
- BYTE
Range: 0-15
ADCSampleArray10
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
Range: 0-5
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
COM Port
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
Servo
Console
Console Log
Log Mode
