| Author
Matrix Ltd
| Version
1.5
| Category
Buffer
Circular Buffer (16-bit) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific 16-bit values.
Please click here to view the component source code (Beta): FC_Comp_Source_CircularBuffer16.fcfx
WaitForValues
| Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
- UINT
Values
- BYTE
NumValues
| Number of values to try and look for
- BYTE
RemoveContent
| 0=Leave the buffer contents untouched, 1=Remove values as you go
- UINT
Timeout
| Max amount of time to wait in milliseconds before returning 0=WaitForever
- BYTE
GetNumberValues
| Returns the number of valid 16-bit data values currently stored inside the buffer.
- UINT
PeekData
| Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty.
- UINT
PutData
| Add a 16-bit value to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
- UINT
Data
- BYTE
LookForValues
| Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
- UINT
Values
- BYTE
NumValues
| The number of values you wish to try and match
- BYTE
RemoveContent
| 0=Leave data alone, 1=Remove data from buffer
- BYTE
ResetFind
| 0=Continue the find from the last operation, 1=Start again
- BYTE
GetData
| Reads the next available 16-bit value from the circular buffer, Returns the default value if the buffer is empty.
- UINT
FlushBuffer
| Clears the contents of the buffer and re-initialises the index locations.
GetIndexedValue
| Gets the value of a single 16-bit value at a known location in the buffer. Leaves the buffer contents and pointers untouched.
- UINT
address
- UINT
Buffer Size
| Sets the number of byte elements inside the circular buffer. The maximum number of bytes that can be stored at any one time is this number minus 1.
Storage Type
| When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Memory Type
Default Return Data
| Specifies the value returned by the receive function when there is no data held in the buffer
WaitForValues
- UINT
Values
- BYTE
NumValues
- BYTE
RemoveContent
- UINT
Timeout
- BYTE
GetNumberValues
- UINT
PeekData
- UINT
PutData
- UINT
Data
- BYTE
LookForValues
- UINT
Values
- BYTE
NumValues
- BYTE
RemoveContent
- BYTE
ResetFind
- BYTE
GetData
- UINT
FlushBuffer
GetIndexedValue
- UINT
address
- UINT
Buffer Size
Storage Type
Memory Type
Default Return Data
