Component: DSPBuffer (DSP)
| Category | DSP |
DSPBuffer component
Creates a DSP buffer to be embedded into a DSP component to hold any output values.
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Buff.fcfx
Some examples containing the Input ADC component.
| Prv_PutPropStr | |
| Idx | |
| Val | |
| Prv_PutConsole | |
| Idx | |
| Val | |
| get | |
| Embedded - Get/Set uses Type Specified to maintain efficiency Sim - Reverts to long type so 8/16 bit will also fit | |
| idx | |
| put | |
| idx | |
| val | |
| put_float | |
| idx | |
| val | |
| Prv_GetPropStr | |
| Idx | |
| Prv_GetConsole | |
| Idx | |
| get_float | |
| idx | |
| Properties | |
| Val | |
| Parent Name | |
| Buffer Size | |
| Buffer Type | |
| Data Recorder Trace | |
| Console | |
| Console Size | |
| Text | |
| Orientation | |
| Enabled | |
| Prv_PutPropStr | |
| Idx | |
| Val | |
| Prv_PutConsole | |
| Idx | |
| Val | |
| get | |
| idx | |
| put | |
| idx | |
| val | |
| put_float | |
| idx | |
| val | |
| Prv_GetPropStr | |
| Idx | |
| Prv_GetConsole | |
| Idx | |
| get_float | |
| idx | |
| Properties | |
| Val | |
| Parent Name | |
| Buffer Size | |
| Buffer Type | |
| Console | |
| Console Size | |
| Text | |
| Orientation | |
| Enabled | |
