Component: Electrical Machines (AllCode)
| Version | 2.0 |
| Category | AllCode |
Electrical Machines component
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here to view the component source code (Beta): FC_Comp_Source_EM_Functions.fcsx
| GetLogDataReady | |
| Checks to see if the logging is complete and ready to read. | |
| GetRPM | |
| Reads the speed in RPM | |
| GetWeight | |
| Reads the voltage of a single channel | |
| Scale | |
| Range: 0-1 - 0=Weight, 1=Torque | |
| SetControlKP | |
| Value | |
| SetControlSetpoint | |
| Value | |
| GetAPIVersion | |
| Reads the API firmware version | |
| GetLogData | |
| Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK | |
| Buffer | |
| Buffer to store the incoming log data | |
| GetSafetySwitch | |
| Reads the safety switch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| SetControlMaxDrivePercentage | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| 0=DC, 1=1 Phase, 2=3 Phase | |
| SetLoadCellCalibration | |
| Value | |
| GetVoltage | |
| Channel | |
| Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT | |
| GetControlFeedback | |
| SetControlKD | |
| Value | |
| SetCapacitorBank | |
| Cap | |
| GetCommsOK | |
| Checks if comms are ok and stable | |
| GetLogStartAngle | |
| Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data. | |
| SetVoltage | |
| Sets the DC Voltage from 0 to 24V | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| Checks to see if the brushless mode is enabled | |
| GetAbsPosition | |
| Reads the absolute position of the encoder | |
| SetFan | |
| |Sets the speed of the FAN from 0 (MIN) to 3000 (MAX) | |
| Speed | |
| SetMotorDirection | |
| MotorDirection | |
| 0=FW, 1=BW | |
| GetMotorDirection | |
| Reads the motor direction | |
| SetThreePhaseDriveMode | |
| Mode | |
| 0=Simple, 1=Accurate | |
| GetCurrent | |
| Reads the current of a single channel | |
| Channel | |
| Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver | |
| SetFrequency | |
| Frequency | |
| Frequency of sine wave in Hz | |
| SetDynoLoad | |
| Load | |
| GetControlOutputs | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| 0=PWM, 1=On/Off/Float | |
| SetTCPProps | |
| Sets the TCP IP address and Port | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| Resets the absolute motor position to 0 | |
| Returns 1 if the connection is ok and communications have been established | |
| MotorType | |
| 0=DC, 1=1Phase, 2=3Phase, 3=AngleControl | |
| GetLogDataReady | |
| GetRPM | |
| GetWeight | |
| Scale | |
| SetControlKP | |
| Value | |
| Value | |
| GetAPIVersion | |
| GetLogData | |
| Buffer | |
| GetSafetySwitch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| Value | |
| GetVoltage | |
| Channel | |
| SetControlKD | |
| Value | |
| Cap | |
| GetCommsOK | |
| SetVoltage | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| GetAbsPosition | |
| SetFan | |
| Speed | |
| MotorDirection | |
| 0=FW, 1=BW | |
| Mode | |
| GetCurrent | |
| Channel | |
| SetFrequency | |
| Frequency | |
| SetDynoLoad | |
| Load | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| SetTCPProps | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| MotorType | |
