Component: Timed Event Trigger (Runtime Tools)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Category Runtime Tools
Timed Event Trigger component
Component that will check to see if a predetermined amount of time has passed. Useful for doing things on a regular basis, e.g. every minute or every hour.
Please click here to view the component source code (Beta): FC_Comp_Source_EventTrigger.fcfx
Reset
Resets the countdown timer
SetTimePeriod
Sets the time period in seconds. Ideally this should only be called when the timer is not running. Automatically stops, resets and restarts the timer if already running.
- ULONG Time
Time period in units specified
- BYTE Units
0=Seconds, 1=Minutes, 2=Hours
Stop
Stops the countdown timer running
CheckTrigger
Checks the state of the trigger to determine if the allocated amount of time has passed. Returns true if amount of time has passed, otherwise returns false.
- BOOL Return
Start
Starts the countdown timer running. Automatically performs a reset if the event has already been triggered.
Time Period Units
Units of time to wait for
Time Period Value
Number of time periods to wait before firing
Call a macro
Decides if a user macro wil be called when the event time period is over. No - requires the use of polling in your application by calling the CheckTrigger component macro. Yes - Automatically calls the selected user macro
Auto Reset
Yes: Automatically resets and restarts the timer when running and actioned. No: Waits for the user to restart the timer running by calling the Start macro.
Reset
SetTimePeriod
- ULONG Time
- BYTE Units
Stop
CheckTrigger
- BOOL Return
Start
Time Period Units
Time Period Value
Call a macro
Auto Reset
