Author
Matrix Ltd
Version
1.9
Category
Graphical Monochrome
GLCD (SSD1306) I2C component
Graphical display component based on the I2C version of the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1306_I2C.fcfx
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
Allows the display to be switched on and off
- BYTE
Control
0=Off, 1=On
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ControlContrast
Sets the display contrast from 0 to 255.
- BYTE
Contrast
Range 0 - 255, Default 207
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Interlaced
Offset X
Offset Y
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
I2C Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
- BYTE
Control
0=Off, 1=On
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ControlContrast
- BYTE
Contrast
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Interlaced
Offset X
Offset Y
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
I2C Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Simulate Comms
