Component: LCD (Generic, 16x2) (Alphanumeric)
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Alphanumeric
LCD (Generic, 16x2) component
LCD based on the unit used in the Matrix EB005 E-block
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_16X2.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
FC6 Icon.png LCD Example
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Enter the text or variable to print to the LCD
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-type-5-icon.png Data 0 (11)
Fc9-type-5-icon.png Data 1 (12)
Fc9-type-5-icon.png Data 2 (13)
Fc9-type-5-icon.png Data 3 (14)
Fc9-type-5-icon.png Register Select (4)
Fc9-type-5-icon.png Enable (6)
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Colour surrounding the font characters drawn on the display
Fc9-type-1-icon.png Display Background
Colour of the background of the display
Values 0 to 7
0 = left, 1 = right
