Component: LED (EB004) (E-blocks 1)
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category E-blocks 1
LED component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_EB004.fcfx
LED Resistor Calculator Tool
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
- BYTE Length
How many items to light up.
LEDOn
Turn on the selected LED.
- BYTE Index
Index of the LED to turn on.
AllOn
Turns on all elements
LEDOff
Turn off the selected led.
- BYTE Index
PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
- BYTE Index
The LED to show.
WriteValue
Write a number which is presented on the LEDs in binary.
- BYTE Value
Provide a value to be written to the LEDs in binary
AllOff
Turns off all elements
Output Mode
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Port
BarGraph
- BYTE Length
LEDOn
- BYTE Index
AllOn
LEDOff
- BYTE Index
PointGraph
- BYTE Index
The LED to show.
WriteValue
- BYTE Value
AllOff
Output Mode
Port
