Component: RGB LED LP5030 LP5036 (LEDs)
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Category LEDs
RGB LED LP5030 LP5036 component
An I2C Based RGB LED driver with 30 or 36 individual constant-current sinks. Used to drive 10 or 12 RGB LEDs with a wide range of applications.
Please click here to view the component source code (Beta): FC_Comp_Source_LP5036_RGB_LED.fcfx
Fc9-comp-macro.png GetRGB
Gets the RGB colour of a single LED.
Range: 0-11
Fc9-u8-icon.png - BYTE RGB
Byte array containing at least 3 bytes to store Red, Green and Blue
Fc9-comp-macro.png SetBrightness
Allows the brightness of a single LED to be specified as a byte from 0 to 255. Default on reset is 255.
Range: 0-11
Fc9-u8-icon.png - BYTE Brightness
Brightness value: Range 0-255
Fc9-comp-macro.png ReadReg
Reads the data from one or more sequential registers
Fc9-u8-icon.png - BYTE Data
Fc9-u8-icon.png - BYTE Count
Fc9-comp-macro.png WriteReg
Writes data to one or more sequential registers
Fc9-comp-macro.png SetRGB
Allows the colour of a single LED to be specified in RGB.
Range: 0-11
Byte array containing at least 3 bytes to set Red, Green and Blue
Fc9-comp-macro.png GetBrightness
Gets the brightness of a single LED.
Range: 0-11
Fc9-comp-macro.png SetUnitAddress
Allows the component to taklk to more then one IC or broadcast to all connected ICs.
Range: 0-3 = Individual / 4 = Broadcast
Fc9-comp-macro.png Initialise
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called.
Fc9-conn-icon.png Driver
Fc9-type-16-icon.png Driver IC
Fc9-type-16-icon.png Address Pins
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Fc9-conn-icon.png Simulation
Range: 0-11
Range: 0-11
Range: 0-11
Range: 0-11
Channel selection
