| Author
MatrixTSL
| Version
1.2
| Category
Comms: Interface
LIN Master component
Low level routines for controlling a LIN master (1.3 & 2.0) interface.
Please click here to view the component source code (Beta): FC_Comp_Source_LinMasterV2.fcfx
UpdateBaud
| Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
- BYTE
new_baud
PowerDown
| Power Down the device
SendMessageTxData
| Sends a message to the slave along with data
- BYTE
Identifier
| 6-Bit ID field, Range: 0x00 to 0x3F
- BYTE
ChecksumType
| 0=Classic (LIN 1.3), 1=Enhanced (LIN 2.0)
- BYTE
DataCount
| Number of data bytes to transmit to the slave, Range: 0 to 8
- BYTE
Data
| Data array to send to the slave
SendMessageRxData
| Sends message with specified identifier and awaits a reply from a slave. Returns the number of data bytes received, 254 for a timeout or 255 for a checksum error.
- BYTE
Identifier
- BYTE
ChecksumType
- BYTE
ResponseCount
| Number of bytes to receive from the slave, Range: 0 to 8
- BYTE
ResponseData
| Data array to pass the received data
- BYTE
WakeUp
| Wake Up the device
| Initialise the component
Bus Options
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
Receive Timeout
| The number of milliseconds to wait for incoming data to be received from the slave.
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
CS
| LIN bus chip select pin
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Format
| Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
UpdateBaud
- BYTE
new_baud
PowerDown
SendMessageTxData
- BYTE
Identifier
- BYTE
ChecksumType
- BYTE
DataCount
- BYTE
Data
SendMessageRxData
- BYTE
Identifier
- BYTE
ChecksumType
- BYTE
ResponseCount
- BYTE
ResponseData
- BYTE
WakeUp
| Wake Up the device
Bus Options
Baud Options
Receive Timeout
TX
TX Remap Pin
RX
RX Remap Pin
CS
Console Format
Console Columns
Data Source
