| Author
| Version
2.0
| Category
Calculation
Map Function component
The map function is intended to change one range of values into another range of values. For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
Please click here to view the component source code (Beta): FC_Comp_Source_Map-Function.fcfx
MapUlong
| Map function for unsigned long type variables
- ULONG
Value
| Main variable used for map function
- ULONG
InMin
| Lowest input value
- ULONG
InMax
| Highest value input
- ULONG
OutMin
| Lowest value after conversion
- ULONG
OutMax
| highest value after conversion
- BOOL
ClampMinMax
| Clamp min & max so result does not go above or below set values. 0=No, 1=Yes
- ULONG
MapInt
| Map function for signed int type variables
- INT
Value
- INT
InMin
| Lowest input value
- INT
InMax
| Highest value input
- INT
OutMin
- INT
OutMax
- BOOL
ClampMinMax
- INT
MapFloat
| Map function for floating point type variables
- FLOAT
Value
- FLOAT
InMin
| Lowest input value
- FLOAT
InMax
| Highest value input
- FLOAT
OutMin
- FLOAT
OutMax
- BOOL
ClampMinMax
- FLOAT
MapLong
| Map function for signed long type variables
- LONG
Value
- LONG
InMin
| Lowest input value
- LONG
InMax
| Highest value input
- LONG
OutMin
- LONG
OutMax
- BOOL
ClampMinMax
- LONG
MapUInt
| Map function for unsigned int type variables
- UINT
Value
- UINT
InMin
| Lowest input value
- UINT
InMax
| Highest value input
- UINT
OutMin
- UINT
OutMax
- BOOL
ClampMinMax
- UINT
MapByte
| Map function for byte type variables
- BYTE
Value
- BYTE
InMin
| Lowest input value
- BYTE
InMax
| Highest value input
- BYTE
OutMin
- BYTE
OutMax
- BOOL
ClampMinMax
- BYTE
MapUlong
- ULONG
Value
- ULONG
InMin
| Lowest input value
- ULONG
InMax
| Highest value input
- ULONG
OutMin
- ULONG
OutMax
- BOOL
ClampMinMax
- ULONG
MapInt
- INT
Value
- INT
InMin
| Lowest input value
- INT
InMax
| Highest value input
- INT
OutMin
- INT
OutMax
- BOOL
ClampMinMax
- INT
MapFloat
- FLOAT
Value
- FLOAT
InMin
| Lowest input value
- FLOAT
InMax
| Highest value input
- FLOAT
OutMin
- FLOAT
OutMax
- BOOL
ClampMinMax
- FLOAT
MapLong
- LONG
Value
- LONG
InMin
| Lowest input value
- LONG
InMax
| Highest value input
- LONG
OutMin
- LONG
OutMax
- BOOL
ClampMinMax
- LONG
MapUInt
- UINT
Value
- UINT
InMin
| Lowest input value
- UINT
InMax
| Highest value input
- UINT
OutMin
- UINT
OutMax
- BOOL
ClampMinMax
- UINT
MapByte
- BYTE
Value
- BYTE
InMin
| Lowest input value
- BYTE
InMax
| Highest value input
- BYTE
OutMin
- BYTE
OutMax
- BOOL
ClampMinMax
- BYTE
