Component: Serial EEPROM (93C46) (EEPROM)
| Author | MatrixTSL |
| Category | EEPROM |
Serial EEPROM (93C46) component
A simple example showing the bare bones used to create a component based on SPI communications. ORG pin must be connected to GND
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(93C46).fcfx
| Erase | |
| Address | |
| Read | |
| 8bit mode address = 0 to 128 Data = 0 to 255 16bit mode address = 0 to 64 Data = 0 to 65535 | |
| address | |
| Write | |
| address | |
| Value | |
| SendBits | |
| A simple example showing a generic way to write a register using I2C. | |
| value | |
| length | |
| EraseAll | |
| Properties | |
| Mode | |
| Connections | |
| CS | |
| EEPROM pin 1 | |
| SK | |
| EEPROM pin 2 | |
| DI | |
| EEPROM pin 3 | |
| DO | |
| EEPROM pin 4 | |
| Operations | |
| Control Codes | |
| Erase | |
| Address | |
| Read | |
| address | |
| Write | |
| address | |
| Value | |
| SendBits | |
| value | |
| length | |
| EraseAll | |
| Properties | |
| Mode | |
| Connections | |
| CS | |
| EEPROM pin 1 | |
| SK | |
| EEPROM pin 2 | |
| DI | |
| EEPROM pin 3 | |
| DO | |
| EEPROM pin 4 | |
| Operations | |
| Control Codes | |
