Component: Joystick (Sparkfun Quiic) (Analog Input)
| Category | Analog Input |
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to view the component source code (Beta): FC_Comp_Source_Sparkfun_Quiic_Joystick.fcfx
| CheckButton | |
| Checks to see if the button has been pressed since the last read of CheckButton or ReadButton. | |
| ReadAxis | |
| Reads a single axis of the joystick and returns as a signed integer value. | |
| Axis | |
| Range 0-1 Where 0=X, 1=Y | |
| Type | |
| 0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023) | |
| ReadButton | |
| Checks to see if the button is currently pressed | |
| Initialises the I2C bus ready for communications with the module. | |
| CheckButton | |
| ReadAxis | |
| Axis | |
| Type | |
| ReadButton | |
