Component: Thermistor Template (Sensors)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix
Category Sensors
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C. FC6 Icon.png EBM003 Example
Fc9-comp-macro.png GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png SetChannel
Set the ADC Channel
Fc9-s16-icon.png - INT ChannelID
Fc9-comp-macro.png GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
Fc9-comp-macro.png CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
Fc9-u16-icon.png - UINT ADCValue
ADC Reading to be converted
Fc9-comp-macro.png GetADCValue
Returns the Raw ADC value from the Analogue Channel
Fc9-comp-macro.png SetTemperature
Simulation macro that sets the internal ADC value to the appropriate value for a given temperature. This allows all internal systems of the sensor to be simulated.
Fc9-f32-icon.png - FLOAT Temperature
The temperature in C - restricted to -25 to +125 range
Fc9-type-6-icon.png ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Fc9-type-16-icon.png Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
Fc9-type-21-icon.png ADC Bit Resolution
Fc9-type-21-icon.png Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
Fc9-type-21-icon.png -25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
Fc9-type-21-icon.png 0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Fc9-type-21-icon.png 25C Thermistor Value
Value in Ohms of the Thermistor at 25 deg C
Fc9-type-21-icon.png 50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
Fc9-type-21-icon.png 75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
Fc9-type-21-icon.png 100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
Fc9-type-21-icon.png 125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
Set the ADC Channel
