Component: Timer (Timing)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Timing
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponent.fcfx
Fc9-comp-macro.png GetCountSeconds
Returns the count value as a number of whole seconds, rounded down to the nearest second
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png StartCounter
Starts the timer counting.
Fc9-bool-icon.png - BOOL ResetCounters
Range: 0-1 where 0=Do Not Reset and 1=Reset
Fc9-comp-macro.png GetCountString
Returns the count value as a floating point string in seconds.
Fc9-u8-icon.png - BYTE Precision
Number of decimal places to display in string
Fc9-comp-macro.png GetCountMicroSeconds
Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond
Fc9-comp-macro.png GetCountMilliseconds
Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond
Fc9-comp-macro.png StopCounter
Stops the timer counting.
Fc9-comp-macro.png ResetCounter
Fc9-comp-macro.png GetCountReal
Returns the count value as a floating point value in seconds.
Fc9-comp-macro.png GetRawCount
Efficient command to collect the integer number of instructions since the timer was started.
Fc9-type-16-icon.png Timer
Timer Peripheral to use to monitor the passage of time.
Fc9-type-21-icon.png Bit Depth
Number of bits in the timer peripheral. 8-bit timers can count from 0-255 before overflowing. 16-bit timers can count from 0 to 65535 before overflowing.
Fc9-type-21-icon.png Instruction Rate
Fc9-type-15-icon.png Rollover Frequency
Fc9-type-15-icon.png Rollover Time
Fc9-type-15-icon.png Max Time Measurement
Max time in seconds that we can measure before rolling over and starting again.
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Timer Delay (ms)
Number of milliseconds between timer events which increment the simulated timer counter variable. 10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow. Higher delays will yield greater accuracy.
Fc9-type-21-icon.png Decimal Points
