Author
MatrixTSL
Version
1.0
Category
Misc Circuit
RGB Xmas Tree component
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
Please click here to view the component source code (Beta): FC_Comp_Source_XmasTree.fcfx
For more information please refer to the Xmas Tree blog post.
PlayNote
Plays a specific note for the length of time specified.
- BYTE
Note
0-59 - 0=C, 1=C#, 2=D, 3=Eb, 4=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=Bb, 11=B, 12=C...
- UINT
Length
WaitAudio
Checks to see if the audio circuit is current outputting a tone. If it is then the macro will wait until the audio is free again.
- UINT
Delay
Optional ms delay after the audio has stopped playing 0=No Delay
SetColours
Generates a colour value based on the input colour parameters and asigns it to all of the LEDs.
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
Green 0=None, 255=Max
- BYTE
Blue
Blue 0=None, 255=Max
RandomLED
Randomises the colour to a specific LED
- BYTE
LED
LED 0 to NumLEDs - 1
MoveToColour
Generates a colour value based on the input colour parameters and transitions one of the LEDs to the new colour. Remains in the function until the new colour has been reached.
- BYTE
LED
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
- UINT
TransistionDelay
Delay in milliseconds between each transition
SetLED
Directly sets the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
LED
- BYTE
Colour
JingleBells
Plays the Jingle Bells tune using the audio driver.
SetLEDs
Sets the colour of all the LEDs. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
Colour
CheckSwitch
Checks to see if the switch is pressed. Returns 1 to indicate a press and 0 to indicate not pressed.
- BYTE
SetColour
Generates a colour value based on the input colour parameters and asigns it to one of the LEDs.
- BYTE
LED
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
CheckAudio
Checks to see if the audio circuit is current outputting a tone. Returns 1 to indicate audio active and 0 to indicate not active.
- BYTE
RandomLEDs
Randomises the colour of all the LEDs
GetLED
Directly read the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
LED
- BYTE
Starts up the LED PWM and Audio software driver.
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
Number of octal buffer IC's you will require to drive the LEDs. Note that the microcontroller data port provides the first buffer so the numbr of ICs is actually one less than the value shown.
Number LEDs
Test On Startup
Performs a simple LED test routine on start up. LEDs should all light up white, red, green and blue in second intervals.
PlayNote
- BYTE
Note
- UINT
Length
WaitAudio
- UINT
Delay
SetColours
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
RandomLED
- BYTE
LED
MoveToColour
- BYTE
LED
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
- UINT
TransistionDelay
SetLED
- BYTE
LED
- BYTE
Colour
JingleBells
SetLEDs
- BYTE
Colour
CheckSwitch
- BYTE
SetColour
- BYTE
LED
- BYTE
Red
Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
CheckAudio
- BYTE
RandomLEDs
GetLED
- BYTE
LED
- BYTE
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
Number LEDs
Test On Startup
