Component: Potentiometer (Trimmer) ()
Revision as of 15:18, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Please click here to view the component source code (Beta): FC_Comp_Source_pot_Trimmer.fcfx
Potentiometer Example
Start Angle
Sweep Angle
Color
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Set Value
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Start Angle
Sweep Angle
Color
Retain Value
Set Value
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
