Component: Slider control (Advanced Shapes)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Advanced Shapes |
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Please click here to view the component source code (Beta): FC_Comp_Source_slider.fcfx
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
Meters
| GetValue | |
| Gets the current value of the slider. This will be within the range set by the SetRange macro. | |
| SetValue | |
| Set the current value of the slider. This will override any value set by using the mouse. | |
| Value | |
| The value to set. | |
| SetInteractive | |
| Set whether the mouse can be used to change the slider value. | |
| Enable | |
| Set true to allow clicks to set scale | |
| ShowScale | |
| Set whether graduated marking are shown along the length of the slider. | |
| Show | |
| True to show scale, else false | |
| SetRange | |
| Set the minimum and maximum values that can be shown on the slider. | |
| Min | |
| Min (start) value | |
| Max | |
| Maximum (end) value | |
| Properties |
| GetValue | |
| SetValue | |
| Value | |
| SetInteractive | |
| Enable | |
| ShowScale | |
| Show | |
| SetRange | |
| Min | |
| Max | |
| Properties |
