Component: Switch (EB007) (E-blocks 1)
Revision as of 15:18, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category E-blocks 1
Switch component
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
Please click here to view the component source code (Beta): FC_Comp_Source_switch_array_push_EB007.fcfx
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
GetHandle
Retrieves the object handle of the switch component at the given index.
- BYTE Index
- HANDLE Return
WaitUntilLow
- BYTE Index
Count
The number of LEDs in the array from 1 to 8.
Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Port
Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
ReadState
- BYTE Index
- BOOL Return
WaitUntilHigh
- BYTE Index
ReadAll
GetHandle
- BYTE Index
- HANDLE Return
WaitUntilLow
- BYTE Index
Count
Input Mode
Port
Debounce
