Component: CNC Machine (Scenarios)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix
Category Scenarios
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Please click here to download the component source project: FC_Comp_Source_CNCComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CNCComponent_v002.fcfx
ZAxisMovement
Moves the components Z axis by 0.01mm. Direction determines direction 1= Down 0 = Up If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component down. 0 will move it up.
Drill_Speed
Will cause the drill to rotate according to the speed. If no speed is set it will stay static.
- FLOAT DrillSpeed
Speed of the Drill. 0=Stopped
MoveToXYZ
Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation.
- FLOAT X
- FLOAT Y
- FLOAT Z
YAxisMovement
Moves the components Y axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component right. 0 will move it left.
HomeMachine
Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0.
XAxisMovement
Moves the components X axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component forward. 0 will move it up.
ResetCoordinates
Resets the coordinates to the home position 0,0,0.
Enables the three motors within the component allowing for movement when any of the Axis macros are called.
ZAxisMovement
- BYTE Direction
Drill_Speed
- FLOAT DrillSpeed
MoveToXYZ
- FLOAT X
- FLOAT Y
- FLOAT Z
YAxisMovement
- BYTE Direction
HomeMachine
XAxisMovement
- BYTE Direction
ResetCoordinates
ZAxisMovement
- BYTE Direction
Drill_Speed
- FLOAT DrillSpeed
MoveToXYZ
- FLOAT X
- FLOAT Y
- FLOAT Z
YAxisMovement
- BYTE Direction
HomeMachine
XAxisMovement
- BYTE Direction
ResetCoordinates
