| Author
Matrix TSL
| Version
1.0
| Category
E-blocks 1
Combo Board component
A component to drive the EB083 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Please click here to download the component source project: FC_Comp_Source_EB086_DEMO.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB086_DEMO.fcfx
The following files provide examples of how to use this component:
Arduino Mega 2560 & Combo Board
- This blank project consists of the Matrix EB083 Combo Board connected to an Arduino Mega 2560.
Arduino Uno R3 & Combo Board
- This blank project consists of the Matrix EB093 Combo Board connected to an Arduino Uno R3.
- Note; Due to a limitation in the Arduino Uno hardware, portA6 & PortA7 are replicated from PortA5 in this template.
Seg_ShowDigit
| Displays a digit on the 7-seg display
- BYTE
Digit
| Which of the digits to change (0 - 3)
- BYTE
Value
| The value to display (0 - 9)
- BYTE
DecimalPoint
| Decides if the decimal point is lit
LCD_PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
- ULONG
Number
| Enter the number or variable to print to the LCD
- BOOL
Format
| 0=Signed, 1=Unsigned
LCD_RemapCharacter
| Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE
RemapIdx
| Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE
SearchCharacter
| Character to look for a replace
- BYTE
ReplacementCharacter
| New character value to use in place of the search character.
LCD_ScrollDisplay
| Scrolls the display left or right by a number of given positions.
- BYTE
Position
| Holds the number of positions to shift the display
- BYTE
Direction
| 0 = left, 1 = right
IO_SetPort
| Sets the state of a single port
- BYTE
Bank
| 0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
- BYTE
Value
IO_SetLEDState
| Sets the state of a single LED
- BYTE
Bank
- BYTE
LED
| 0 = LED0, 7 = LED7
- BYTE
State
| 0 = Off, 1 = On
LCD_PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
- FLOAT
Number
- BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
IO_GetPort
| Reads the state of a single port
- BYTE
Bank
| 0 = Top Bank of Switches, 1 = Bottom Bank of Switches
- BYTE
LCD_Cursor
| Moves the cursor on the LCD Display
- BYTE
x
| Set the cursor position in the X plane, 0 is the left most cell
- BYTE
y
| Set the cursor position in the Y plane, 0 is the top most cell
Seg_ShowSegments
| Allows the individual segments of the display to be controlled.
- BYTE
Digit
- BYTE
Segments
| 8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
LCD_Start
| Startup routine required by the hardware device. Automatically clears the display after initialising.
LCD_Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
- BYTE
instruction
| Send a defined command to the LCD Screen. See datasheet for supported commands.
LCD_RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
- BYTE
Index
| Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
IO_ReadAnalogAsInt
| Reads one of the analogue components as an Integer value
- BYTE
| 0 = Light Sensor, 1 = Potentiometer
- INT
LCD_PrintString
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
- STRING
Text
| Enter the text or variable to print to the LCD
LCD_ClearLine
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data.
- BYTE
Line
| The line to clear, zero being the first (top) line of the display
IO_GetSwitchState
| Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed
- BYTE
Bank
- BYTE
Switch
| 0 = SW0, 7 = SW7
- BYTE
IO_ReadAnalogAsByte
| Reads one of the analogue components as an byte value
- BYTE
- BYTE
LCD_PrintAscii
| Takes the ascii value for a character and prints the character
- BYTE
character
| Holds an ascii value.
LCD_PrintNumber
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
LCD_RawSend
| Sends data to the LCD display
- BYTE
data
| The data byte to send to the LCD
- BOOL
type
| A boolean to indicate command type: true to write data, false to write a command
LCD_Clear
| Clears the entire contents of the display.
Connection Type
Bank 0 Connections
Bank 0
Bank 1 Connections
Bank 1
Analog Connections
Light Sensor
| Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0.
Potentiometer
| Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1.
Analog Scope Traces
| Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
Seg_ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
- ULONG
Number
- BOOL
Format
LCD_RemapCharacter
- BYTE
RemapIdx
- BYTE
SearchCharacter
- BYTE
LCD_ScrollDisplay
- BYTE
Position
- BYTE
Direction
| 0 = left, 1 = right
IO_SetPort
- BYTE
Bank
- BYTE
Value
IO_SetLEDState
- BYTE
Bank
- BYTE
LED
| 0 = LED0, 7 = LED7
- BYTE
State
| 0 = Off, 1 = On
LCD_PrintFloat
- FLOAT
Number
- BYTE
DecimalPlaces
IO_GetPort
- BYTE
Bank
- BYTE
LCD_Cursor
- BYTE
x
- BYTE
y
Seg_ShowSegments
- BYTE
Digit
- BYTE
Segments
LCD_Start
LCD_Command
- BYTE
instruction
LCD_RAMWrite
- BYTE
Index
| Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
IO_ReadAnalogAsInt
- BYTE
- INT
LCD_PrintString
- STRING
Text
LCD_ClearLine
- BYTE
Line
IO_GetSwitchState
- BYTE
Bank
- BYTE
Switch
| 0 = SW0, 7 = SW7
- BYTE
IO_ReadAnalogAsByte
- BYTE
- BYTE
LCD_PrintAscii
- BYTE
character
LCD_PrintNumber
- INT
Number
LCD_RawSend
- BYTE
data
- BOOL
type
LCD_Clear
Connection Type
Bank 0 Connections
Bank 0
Bank 1 Connections
Bank 1
Analog Connections
Light Sensor
Potentiometer
Analog Scope Traces
Seg_ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
- ULONG
Number
- BOOL
Format
LCD_RemapCharacter
- BYTE
RemapIdx
- BYTE
SearchCharacter
- BYTE
LCD_ScrollDisplay
- BYTE
Position
- BYTE
Direction
| 0 = left, 1 = right
IO_SetPort
- BYTE
Bank
- BYTE
Value
IO_SetLEDState
- BYTE
Bank
- BYTE
LED
| 0 = LED0, 7 = LED7
- BYTE
State
| 0 = Off, 1 = On
LCD_PrintFloat
- FLOAT
Number
- BYTE
DecimalPlaces
IO_GetPort
- BYTE
Bank
- BYTE
LCD_Cursor
- BYTE
x
- BYTE
y
Seg_ShowSegments
- BYTE
Digit
- BYTE
Segments
LCD_Start
LCD_Command
- BYTE
instruction
LCD_RAMWrite
- BYTE
Index
| Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
IO_ReadAnalogAsInt
- BYTE
- INT
LCD_PrintString
- STRING
Text
LCD_ClearLine
- BYTE
Line
IO_GetSwitchState
- BYTE
Bank
- BYTE
Switch
| 0 = SW0, 7 = SW7
- BYTE
IO_ReadAnalogAsByte
- BYTE
- BYTE
LCD_PrintAscii
- BYTE
character
LCD_PrintNumber
- INT
Number
LCD_RawSend
- BYTE
data
- BOOL
type
LCD_Clear
Connection Type
Bank 0 Connections
Bank 0
Bank 1 Connections
Bank 1
Analog Connections
Light Sensor
Potentiometer
Analog Scope Traces
