| Author
Matrix Ltd.
| Version
1.3
| Category
E-blocks 2
Bluetooth component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
ReceiveByte
| Receives a single data byte from the Bluetooth module. 0-255 signifies valid data / 256 signifies no data available.
- UINT
Timeout
| Amount of time to wait in milliseconds 0=Wait forever
- UINT
SendString
| Sends a string to the Bluetooth module.
- STRING
Command
- BYTE
SendCR
LeaveCommandMode
| Leaves command mode allowing data to be passed back and forth,
ConnectToMAC
| Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful.
- STRING
MACAddress
- BOOL
SendCommand
| Sends a command string to the Bluetooth module. Returns: 0 = No Reply / 1 = Command sent ok
- STRING
Command
- BYTE
SendCR
- BYTE
DiscardReply
| 0=Do not touch the reply, 1=Wait for reply and remove from buffer
- BYTE
ReceiveCount
| Returns the number of bytes currently sat waiting in the receive buffer.
- UINT
ReadString
| Copies the incoming data from the data string array to a local string variable.
- BYTE
NumBytes
| Maximum number of bytes to try and read
- STRING
SendByte
| Sends a single data byte out to the Bluetooth module.
- BYTE
Data
EnterCommandMode
| Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK
- BOOL
WaitForStringValue
| Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0.
- STRING
Value
| String value to look for
- UINT
Timeout
| Length of time to wait in milliseconds
- BOOL
GetMACAddress
| Gets the local Bluetooth device MAC address.
- STRING
| Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply.
- BYTE
Bluetooth Settings
Device Name
| Sets the friendly name of the Bluetooth device.
Pair Key
Discoverable
| Is the Bluetooth module discoverable by default?
Reply Timeout
| Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds.
RX Buffer Size
| Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Simulate Comms
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Command
- BYTE
SendCR
LeaveCommandMode
ConnectToMAC
- STRING
MACAddress
- BOOL
SendCommand
- STRING
Command
- BYTE
SendCR
- BYTE
DiscardReply
- BYTE
ReceiveCount
- UINT
ReadString
- BYTE
NumBytes
- STRING
SendByte
- BYTE
Data
EnterCommandMode
- BOOL
WaitForStringValue
- STRING
Value
- UINT
Timeout
- BOOL
GetMACAddress
- STRING
- BYTE
Bluetooth Settings
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Simulate Comms
Console Columns
Data Source
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Command
- BYTE
SendCR
LeaveCommandMode
ConnectToMAC
- STRING
MACAddress
- BOOL
SendCommand
- STRING
Command
- BYTE
SendCR
- BYTE
DiscardReply
- BYTE
ReceiveCount
- UINT
ReadString
- BYTE
NumBytes
- STRING
SendByte
- BYTE
Data
EnterCommandMode
- BOOL
WaitForStringValue
- STRING
Value
- UINT
Timeout
- BOOL
GetMACAddress
- STRING
- BYTE
Bluetooth Settings
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Simulate Comms
Console Columns
Data Source
