Component: RFID (BL0197) (E-blocks 2)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category E-blocks 2
RFID (BL0197) component
Low level routines for controlling a BL0197 RFID E-block 2 board. Complete with macros to control the tag type and buzzer parameters.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_RFID_BL0197.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_RFID_BL0197.fcfx
GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
SetCardType
Allows the RFID tag type to be configured
- BYTE TagType
0 = MIFARE, 1 = ICODE, 2 = ISO14443B
WriteRFIDBlock
Writes a block of information to the RFID device.
- BYTE Address
Remote RFID Block Address.
- BYTE Key_Type
WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
- BYTE Address
- BYTE Data
DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
Needed for MIFARE Commands
FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
- BYTE Key
Key Location 0 - 31
- BYTE D0
Least significant byte of key
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
Most significant byte of key
WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
- BYTE Address
The address of the buffer 0 - 15
- BYTE Data
The data to be stored in the buffer location 0 - 255.
GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
- BYTE Address
TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
ReadRFIDUID
Reads a byte of data from the UID buffer.
- BYTE Address
The address of the buffer 0 - 7
IsTagPresent
Checks to see if a card is present. Returns 0 if no tag is present. Returns 1 if a valid tag is present.
- BOOL Return
SetBeep
Allows the buzzer output to be configured
- BYTE BeepDelay
0 = Off, 1 = 40mS, 2 = 80mS, 3 = 120mS etc.
ReadRFIDBlock
Reads a block of information from the RFID device.
- BYTE Address
- BYTE Key_Type
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
Card_Type
Beep Delay
Amount of time to activate the buzzer when detecting a new RFID tag.
Baud Options
TX
RX
Card Detect (LED)
CTS
Console Columns
Data Source
GetRFIDTypeID
SetCardType
- BYTE TagType
WriteRFIDBlock
- BYTE Address
- BYTE Key_Type
WriteRFIDModule
- BYTE Address
- BYTE Data
DecrementRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
FormatRFIDValue
IncrementRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
StoreRFIDKey
- BYTE Key
Key Location 0 - 31
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
WriteRFIDBuffer
- BYTE Address
- BYTE Data
GetRFIDStatus
ReadRFIDBuffer
- BYTE Address
TransferRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
GetRFIDUID
ReadRFIDUID
- BYTE Address
IsTagPresent
- BOOL Return
SetBeep
- BYTE BeepDelay
ReadRFIDBlock
- BYTE Address
- BYTE Key_Type
Card_Type
Beep Delay
Baud Options
TX
RX
Card Detect (LED)
CTS
Console Columns
Data Source
GetRFIDTypeID
SetCardType
- BYTE TagType
WriteRFIDBlock
- BYTE Address
- BYTE Key_Type
WriteRFIDModule
- BYTE Address
- BYTE Data
DecrementRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
FormatRFIDValue
IncrementRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
StoreRFIDKey
- BYTE Key
Key Location 0 - 31
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
WriteRFIDBuffer
- BYTE Address
- BYTE Data
GetRFIDStatus
ReadRFIDBuffer
- BYTE Address
TransferRFIDValue
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
GetRFIDUID
ReadRFIDUID
- BYTE Address
IsTagPresent
- BOOL Return
SetBeep
- BYTE BeepDelay
ReadRFIDBlock
- BYTE Address
- BYTE Key_Type
Card_Type
Beep Delay
Baud Options
TX
RX
Card Detect (LED)
CTS
Console Columns
Data Source
