Component: EEPROM (EEPROM)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category EEPROM
EEPROM component
A means of reading data from and writing data to the EEPROM memory onboard the microcontroller. Fully functional with simulation but the target microcontroller must have EEPROM memory available to allow compilation to work.
Please click here to download the component source project: FC_Comp_Source_EEPROM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM.fcfx
The Console window can be used to show the contents of EE memory during simulation.
Read and Write Bytes
Reads a value from location 0 in the EEPROM and writes back the value incremented by one, the values are displayed on to a LCD.
Starting and stopping the simulation or resetting the microcontroller will allow the program to resume counting from where it left off as opposed to a standard RAM based variable which would reset to an undetermined value. EEPROM
Read and Write Ints
Reads a value from locations 0,1 in the EEPROM and writes back the value incremented by one, the values are displayed on to a LCD.
Starting and stopping the simulation or resetting the microcontroller will allow the program to resume counting from where it left off as opposed to a standard RAM based variable which would reset to an undetermined value. EEPROM_INT
String variables in EE Memory
Example showing how to store and retrieve strings to and from the EEPROM memory. EEStrings
WriteFloat
Writes a 32-bit float value starting at the specified address. A 32-bit float will consume 4 bytes which will be 4 locations on an 8-bit device or 2 locations on a 16-bit device.
- UINT StartAddress
Initial EE location to start reading
- FLOAT Value
Floating point value to write
- BOOL MSBFirst
0=LSB First, 1=MSB First
ReadInt
Reads a 16-bit int value starting from the specified address. A 16-bit int will consume 2 bytes which will be 2 locations on an 8-bit device or 1 location on a 16-bit device.
- UINT StartAddress
- BOOL MSBFirst
ReadFloat
Reads a 32-bit float value starting from the specified address. A 32-bit float will consume 4 bytes which will be 4 locations on an 8-bit device or 2 locations on a 16-bit device.
- UINT StartAddress
- BOOL MSBFirst
- FLOAT Return
WriteByte
Writes a 8-bit byte value to the specified address. A 8-bit byte will consume 1 bytes which will be 1 locations on an 8-bit device or half a location on a 16-bit device.
- UINT ByteAddress
Byte address, EEADDR on 8-bit device or EEADDR/2 on a 16-bit device
- BYTE Value
WriteInt
Writes a 16-bit int value starting at the specified address. A 16-bit int will consume 2 bytes which will be 2 locations on an 8-bit device or 1 location on a 16-bit device.
- UINT StartAddress
- UINT Value
- BOOL MSBFirst
ReadString
Reads a string of data from the EE memory starting at the specified address. 8-bit EE memory stores a character into each memory location. 16-bit EE memory stores two characters into each memory location.
- UINT StartAddress
EE Address of the first character in the string
- BYTE MaxChars
The maximum number of characters to try and read plus null termination
- STRING Return
Read
Reads a packet of bits from the EEPROM The number of bits read is 8 or 16, depending on the platform
- UINT Address
The address, in elements, to read the data from
ReadLong
Reads a 32-bit long value starting from the specified address. A 32-bit long will consume 4 bytes which will be 4 locations on an 8-bit device or 2 locations on a 16-bit device.
- UINT StartAddress
- BOOL MSBFirst
- ULONG Return
WriteString
Writes a string of data to the EE memory starting at the specified address. 8-bit EE memory stores a character into each memory location. 16-bit EE memory stores two characters into each memory location.
- UINT StartAddress
- BYTE MaxChars
- STRING DataString
Write
Writes a packet of bits from the EEPROM The number of bits written is 8 or 16, depending on the platform
- UINT Address
The address, in elements, to write the data to
- UINT Value
The 8 or 16 bit value to store in EEPROM
ReadByte
Reads a 8-bit byte value starting from the specified address. A 8-bit byte will consume 1 byte which will be 1 locations on an 8-bit device or half a location on a 16-bit device.
- UINT ByteAddress
- BOOL MSBFirst
WriteLong
Writes a 32-bit long value starting at the specified address. A 32-bit long will consume 4 bytes which will be 4 locations on an 8-bit device or 2 locations on a 16-bit device.
- UINT StartAddress
- ULONG Value
- BOOL MSBFirst
EE Size
Number of memory locations available in EEPROM onboard the target microcontroller.
EE Bit Depth
Number of bits in each EEPROM memory location onboard the target microcontroller.
Initial Values
Comma seperated list of values to assign to the EEPROM memory while programming the device. The simulation will automatically load these values into the simulated EE locations on simulation start. Leave blank to remove initialisation code from the compiled C code Supported Formats Decimal 0 - 255 Hexadecimal 0x00 - 0xFF ASCII character 'x' Strings "text"
Reset To Defaults
Decides what to do on a simulation start event. Siim data will reset to initial values after reloading project or changing initial values property. Yes: Resets the contents of the EEPROM data to the initial values. No: EEPROM contents will be retained between simulations.
WriteFloat
- UINT StartAddress
- FLOAT Value
- BOOL MSBFirst
ReadInt
- UINT StartAddress
- BOOL MSBFirst
ReadFloat
- UINT StartAddress
- BOOL MSBFirst
- FLOAT Return
WriteByte
- UINT ByteAddress
- BYTE Value
WriteInt
- UINT StartAddress
- UINT Value
- BOOL MSBFirst
ReadString
- UINT StartAddress
- BYTE MaxChars
- STRING Return
Read
- UINT Address
ReadLong
- UINT StartAddress
- BOOL MSBFirst
- ULONG Return
WriteString
- UINT StartAddress
- BYTE MaxChars
- STRING DataString
Write
- UINT Address
- UINT Value
ReadByte
- UINT ByteAddress
- BOOL MSBFirst
WriteLong
- UINT StartAddress
- ULONG Value
- BOOL MSBFirst
EE Size
EE Bit Depth
Initial Values
Reset To Defaults
WriteFloat
- UINT StartAddress
- FLOAT Value
- BOOL MSBFirst
ReadInt
- UINT StartAddress
- BOOL MSBFirst
ReadFloat
- UINT StartAddress
- BOOL MSBFirst
- FLOAT Return
WriteByte
- UINT ByteAddress
- BYTE Value
WriteInt
- UINT StartAddress
- UINT Value
- BOOL MSBFirst
ReadString
- UINT StartAddress
- BYTE MaxChars
- STRING Return
Read
- UINT Address
ReadLong
- UINT StartAddress
- BOOL MSBFirst
- ULONG Return
WriteString
- UINT StartAddress
- BYTE MaxChars
- STRING DataString
Write
- UINT Address
- UINT Value
ReadByte
- UINT ByteAddress
- BOOL MSBFirst
WriteLong
- UINT StartAddress
- ULONG Value
- BOOL MSBFirst
EE Size
EE Bit Depth
Initial Values
Reset To Defaults
