| Author | Matrix Ltd |
| Version | 1.6 |
GLCD (UC1701) component
Graphical display component based on the UC1701 monochrome graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_UC1701.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_UC1701.fcfx
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - BYTE | Transparent |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | PixelColour |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Interlaced |
| Determines if the display is interlaced in the Y axis or not |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Chip Select (CS) |
| Chip select pin connection |
|   | Reg Select (A0) |
|   | Data (SD) |
| LED backlight strobe pin connection |
|   | Serial Clock (SCK) |
| Reset pin connection |
|   | Reset (RST) |
| Instruction / Command pin connection |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | Physical Orientation |
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Interlaced |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Chip Select (CS) |
|   | Reg Select (A0) |
|   | Data (SD) |
|   | Reset (RST) |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Interlaced |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Connections |
|   | Chip Select (CS) |
|   | Reg Select (A0) |
|   | Data (SD) |
|   | Reset (RST) |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
