| Author
Matrix Ltd
| Version
1.1
| Category
Magnetic
Hall Effect Analog component
Simple analogue hall effect triggered by the proximity of another object.
Please click here to download the component source project: FC_Comp_Source_HallEffect_Analog.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HallEffect_Analog.fcfx
SetTarget
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
  - HANDLE
Target
| The object to test for collision with.
ReadProximityByte
| Get the current proximity reading as a digital value from 0 to 255. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
  - BYTE
ReadProximityFloat
| Get the current proximity as an analogue value from 0.0 to 1.0. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
  - FLOAT
ReadProximityInt
| Get the current proximity as a digital value, 10 bit or 12 bit based on your ADC capabilities. The 'Polarity' property will affect whether the signal increases or decreases as the proximity increases.
  - UINT
Analog Pin
Polarity
| The 'Polarity' property will affect whether the signal increases of decreases as the proximity increases. Rising - Increases signal as proximity increases Falling - Decreases signal as proximity increases
ADC Properties
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Magnet Object
| Select an object from the panel to act as the magnet that triggers the reed switch.
Range
| Distance within which the sensor begins to be activated. NB)  This is measured between the centre of the proximity sensor and the centre of the target object.
Timer Interval (ms)
| Time in milliseconds between testing for proximity. Small time = Greater CPU load Large time = More like to miss activation if it is very brief.
SetTarget
  - HANDLE
Target
ReadProximityByte
  - BYTE
ReadProximityFloat
  - FLOAT
ReadProximityInt
  - UINT
Analog Pin
Polarity
ADC Properties
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Magnet Object
Range
Timer Interval (ms)
SetTarget
  - HANDLE
Target
ReadProximityByte
  - BYTE
ReadProximityFloat
  - FLOAT
ReadProximityInt
  - UINT
Analog Pin
Polarity
ADC Properties
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Magnet Object
Range
Timer Interval (ms)
