| Author
Matrix Ltd
| Version
1.2
| Category
Data Transfer (API UART) component
Comms data injector to allow a Serial UART peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical UART.
Please click here to download the component source project: FC_Comp_Source_InjectorSCADAUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAUART.fcfx
InitialiseInjector
| Sets up the injector ready to receive commands or send data
- STRING
InjectorName
| Name of the console that will be created
- BYTE
TxByte
| Puts a byte onto the comms channel.
- BYTE
DataByte
RxByte
| Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available
- UINT
GetConsoleHandle
| Gets the handle to the console allowing data displaying on the panel etc.
- HANDLE
ChangeState
| Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
- BYTE
State
| SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
SCADA Slave
| SCADA Slave component to use to pipe data to a physical SPI bus
BAUD Rate
| Sets the data bit rate of the Serial UART. See the SCADA Slave UART Baud macro for valid values,
RS485 Direction Control
| Allows an I/O pin to be automatically assigned when transmitting and receiving.
RS485 Properties
RS485 Pin Number
| Digital I/O pin number to use for the RS485 data direction pin
TX Pin State
| Decides the state of the RS485 data direction pin when transmitting data.
RX Pin State
| Decides the state of the RS485 data direction pin when receiving data.
InitialiseInjector
- STRING
InjectorName
- BYTE
TxByte
- BYTE
DataByte
RxByte
- UINT
GetConsoleHandle
- HANDLE
ChangeState
- BYTE
State
SCADA Slave
BAUD Rate
RS485 Properties
RS485 Pin Number
TX Pin State
RX Pin State
InitialiseInjector
- STRING
InjectorName
- BYTE
TxByte
- BYTE
DataByte
RxByte
- UINT
GetConsoleHandle
- HANDLE
ChangeState
- BYTE
State
SCADA Slave
BAUD Rate
RS485 Properties
RS485 Pin Number
TX Pin State
RX Pin State
