Component: Simulation 7 Seg (Misc)
Author | Matrix Ltd |
Version | 1.0 |
Category | Misc |
Simulation 7 Seg component
Simulated single digit seven segment display. LED colour can be changed in properties.
Please click here to download the component source project: FC_Comp_Source_LED_7Seg_Single_Sim_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_7Seg_Single_Sim_2dgi.fcfx
Each segment will require a current limiting resistor.
Basic Multiplexing
Only one of the four 7-segment LEDs can be enabled at a time so we need a way of multiplexing the output so that we can display a number on all four LEDs. To do this we switch between LED outputs at fairly high speed and persistence of vision allows the display to appear fixed and constant.
This example demonstrates a very basic loop to display a four digit number multiplexed across four 7segment displays.
Quad 7Segment Display Example
Timer Based Multiplexing
This example demonstrates a timer interrupt to display a four digit number multiplexed across four 7segment displays. The timer interrupt takes care of updating the display leaving our program free to count up in 100ms increments.
Quad 7Segment Display Example 2
The panel should show the simulation run time down to the current tenth of a second.
Stop Watch
This next example uses a timer interrupt to multiplex between the displays and a second timer interrupt to count the passing of time allowing for accurate timings. Using four single 7-seg components we create a timer capable of monitoring time from 0.0 to 999.9 seconds in multiples of 100ms. The second timer interrupt flags to the main when the count value has changed allowing the heavier calculations to extract the digits from the counter to be done outside of the high speed interrupt routine and therefore maintain accurate timing.
Switches connected to Port D allow for the timer to be started, stopped and reset.
7Segment Timer
SegControl |
Direct control over the display segments | |
data |
Return |
Properties |
Colors |
LED On Color |
Color when an LED is turned on. | |
LED Off Color |
Color when an LED is turned off. | |
Bezel Color |
Color of the plastic package housing the LEDs |
SegControl |
data |
Return |
Properties |
Colors |
LED On Color |
LED Off Color |
Bezel Color |
SegControl |
data |
Return |
Properties |
Colors |
LED On Color |
LED Off Color |
Bezel Color |
SegControl |
data |
Return |
Properties |
Colors |
LED On Color |
LED Off Color |
Bezel Color |
SegControl |
data |
Return |
Properties |
Colors |
LED On Color |
LED Off Color |
Bezel Color |
