Component: LED Array Template (LEDs)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
LED Array Template component
Create an evenly spaced array of LED indicators. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard LED component to change the style.
Please click here to download the component source project: FC_Comp_Source_LED_Array.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array.fcfx
Example program which uses the point graph macro and loops to create a knight rider effect using the LED array.
LED KnightRider
Example program which reads an analogue value from an analogue input voltage and displays the reading in Binary on the LED array.
LED Count
LEDs can be wired either active high or active low. The LED Array components have a property allowing you to configure which LED type your using.
LED Resistor Calculator Tool
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
- BYTE Length
How many items to light up.
LEDOn
Turn on the selected LED.
- BYTE Index
Index of the LED to turn on.
AllOn
Turns on all elements
LEDOff
Turn off the selected led.
- BYTE Index
PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
- BYTE Index
The LED to show.
GetHandle
Retrieves the object handle of the indexed clone. Returns zero for out of range indexes.
- BYTE Index
- HANDLE Return
WriteValue
Write a number which is presented on the LEDs in binary.
- BYTE Value
Provide a value to be written to the LEDs in binary
AllOff
Turns off all elements
Count
The number of LEDs in the array from 1 to 8.
Output Mode
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Port
Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Alignment
Which 3D axis to align the copies along.
Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Reverse
Reverse the direction of the LEDs.
Shape
Target LED
Drag any LED component based on the 'LED base' onto the panel and select it here to use a custom LED design. When unconnected, you can choose a default geometric form instead.
Shape
Shape for the LED when no target is selected.
Width
Width of the LED shape.
Height
Height of the LED shape.
Depth
Depth of the LED shape.
Colors
Same Color
Choose whether all LEDs should be the same color, or to set them individually.
LED 0
The colour for LED 0 - or for all LEDs if that option is set.
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
Set the position of the label relative to the component.
BarGraph
- BYTE Length
LEDOn
- BYTE Index
AllOn
LEDOff
- BYTE Index
PointGraph
- BYTE Index
The LED to show.
GetHandle
- BYTE Index
- HANDLE Return
WriteValue
- BYTE Value
AllOff
Count
Output Mode
Port
Polarity
Alignment
Spacing
Reverse
Shape
Target LED
Shape
Width
Height
Depth
Colors
Same Color
LED 0
Show
Property
Color
Scale
Follow Zoom
Position
BarGraph
- BYTE Length
LEDOn
- BYTE Index
AllOn
LEDOff
- BYTE Index
PointGraph
- BYTE Index
The LED to show.
GetHandle
- BYTE Index
- HANDLE Return
WriteValue
- BYTE Value
AllOff
Count
Output Mode
Port
Polarity
Alignment
Spacing
Reverse
Shape
Target LED
Shape
Width
Height
Depth
Colors
Same Color
LED 0
Show
Property
Color
Scale
Follow Zoom
Position
