Component: LED Array (PCB) ()
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix
Version 1.1
Category
LED Array (PCB) component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_LED_Array_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_pcb.fcfx
Count
The number of LEDs in the array from 1 to 8.
Output Mode
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Port
Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Alignment
Which 3D axis to align the copies along.
Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Reverse
Reverse the direction of the LEDs.
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Label Position
Whether to display the pin labels next to each LED
LED color
The on colour for the LEDs, the off colour is calculated automatically from this.
Label color
Color of the pin labels.
Count
Output Mode
Port
Polarity
Alignment
Spacing
Reverse
Show
Property
Label Position
LED color
Label color
Count
Output Mode
Port
Polarity
Alignment
Spacing
Reverse
Show
Property
Label Position
LED color
Label color
