Component: Bitmap Drawer (Displays: Graphical)
| Version | 1.2 |
| Category | Displays: Graphical |
Bitmap Drawer component
A component to simplify the process of drawing bitmap images to a graphical display. Stores the bitmap image inside a ROM look up table. Compatible with 24-bit Bitmaps and Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Use multiple BitmapDrawer components for multiple bitmap images.
Please click here to download the component source project: FC_Comp_Source_Lib_GLCD_Menu_Unfinished.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_GLCD_Menu_Unfinished.fcfx
The graph creator XY component must be linked to the graphical LCD using the gLCD Object property.
The X Coord, Y Coord, Width and Height component properties set the size and position of the graph on the gLCD.
In the attached example the ADC component sets the input to the graph. Every 50ms a sample is taken and added to the graph.
Any size of graph can be created. For efficiency it is best to try and stick to the following rules.
- The width should be equal to or a multiple of the X input range - Min Value 0 to Max Value 255 = input range of 256
- The height should be equal to or a multiple of the Y input range - Min Value 0 to Max Value 255 = input range of 256
- If Show Border is enabled then Width and Height should be as above plus 2 to account for the border pixels
| Configures the menu and assigns the coordinates on the LCD. | |
| X | |
| Y | |
| Width | |
| Height | |
| Font | |
| X | |
| Y | |
| Width | |
| Height | |
| Font | |
| X | |
| Y | |
| Width | |
| Height | |
| Font | |
