| Author | medelec35 |
| Version | 2.0 |
| Category | Calculation |
Map Function component
The map function is intended to change one range of values into another range of values.  For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
Please click here to download the component source project: FC_Comp_Source_Map-Function.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Map-Function.fcfx
|   | MapUlong |
| Map function for unsigned long type variables |
|  - ULONG | Value |
| Main variable used for map function |
|  - ULONG | InMin |
| Lowest input value |
|  - ULONG | InMax |
| Highest value input |
|  - ULONG | OutMin |
| Lowest value after conversion |
|  - ULONG | OutMax |
| highest value after conversion |
|  - BOOL | ClampMinMax |
| Clamp min & max so result does not go above or below set values. 0=No, 1=Yes |
|  - ULONG | Return |
|   | MapInt |
| Map function for signed int type variables |
|  - INT | Value |
|  - INT | InMin |
|  - INT | InMax |
|  - INT | OutMin |
|  - INT | OutMax |
|  - INT | Return |
|   | MapFloat |
| Map function for floating point type variables |
|  - FLOAT | Value |
|  - FLOAT | InMin |
|  - FLOAT | InMax |
|  - FLOAT | OutMin |
|  - FLOAT | OutMax |
|  - FLOAT | Return |
|   | MapLong |
| Map function for signed long type variables |
|  - LONG | Value |
|  - LONG | InMin |
|  - LONG | InMax |
|  - LONG | OutMin |
|  - LONG | OutMax |
|  - LONG | Return |
|   | MapUInt |
| Map function for unsigned int type variables |
|  - UINT | Value |
|  - UINT | InMin |
|  - UINT | InMax |
|  - UINT | OutMin |
|  - UINT | OutMax |
|  - UINT | Return |
|   | MapByte |
| Map function for byte type variables |
|  - BYTE | Value |
|  - BYTE | InMin |
|  - BYTE | InMax |
|  - BYTE | OutMin |
|  - BYTE | OutMax |
|  - BYTE | Return |
|   | Properties |
|   | MapUlong |
|  - ULONG | Value |
|  - ULONG | InMin |
|  - ULONG | InMax |
|  - ULONG | OutMin |
|  - ULONG | OutMax |
|  - ULONG | Return |
|   | MapInt |
|  - INT | Value |
|  - INT | InMin |
|  - INT | InMax |
|  - INT | OutMin |
|  - INT | OutMax |
|  - INT | Return |
|   | MapFloat |
|  - FLOAT | Value |
|  - FLOAT | InMin |
|  - FLOAT | InMax |
|  - FLOAT | OutMin |
|  - FLOAT | OutMax |
|  - FLOAT | Return |
|   | MapLong |
|  - LONG | Value |
|  - LONG | InMin |
|  - LONG | InMax |
|  - LONG | OutMin |
|  - LONG | OutMax |
|  - LONG | Return |
|   | MapUInt |
|  - UINT | Value |
|  - UINT | InMin |
|  - UINT | InMax |
|  - UINT | OutMin |
|  - UINT | OutMax |
|  - UINT | Return |
|   | MapByte |
|  - BYTE | Value |
|  - BYTE | InMin |
|  - BYTE | InMax |
|  - BYTE | OutMin |
|  - BYTE | OutMax |
|  - BYTE | Return |
|   | Properties |
|   | MapUlong |
|  - ULONG | Value |
|  - ULONG | InMin |
|  - ULONG | InMax |
|  - ULONG | OutMin |
|  - ULONG | OutMax |
|  - ULONG | Return |
|   | MapInt |
|  - INT | Value |
|  - INT | InMin |
|  - INT | InMax |
|  - INT | OutMin |
|  - INT | OutMax |
|  - INT | Return |
|   | MapFloat |
|  - FLOAT | Value |
|  - FLOAT | InMin |
|  - FLOAT | InMax |
|  - FLOAT | OutMin |
|  - FLOAT | OutMax |
|  - FLOAT | Return |
|   | MapLong |
|  - LONG | Value |
|  - LONG | InMin |
|  - LONG | InMax |
|  - LONG | OutMin |
|  - LONG | OutMax |
|  - LONG | Return |
|   | MapUInt |
|  - UINT | Value |
|  - UINT | InMin |
|  - UINT | InMax |
|  - UINT | OutMin |
|  - UINT | OutMax |
|  - UINT | Return |
|   | MapByte |
|  - BYTE | Value |
|  - BYTE | InMin |
|  - BYTE | InMax |
|  - BYTE | OutMin |
|  - BYTE | OutMax |
|  - BYTE | Return |
|   | Properties |
