| Author
Matrix Ltd.
| Version
2.0
| Category
Comms: System
Modbus Slave USB component
Modbus component for creating Modbus compatible slave hardware via USB Serial.
Please click here to download the component source project: FC_Comp_Source_ModbusSlaveUSB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModbusSlaveUSB.fcfx
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
Modbus TCP Slave Example
Addressing
| Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
| Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
| Digital Inputs
Binary inputs
10001
30000
0
19999
| Analog Inputs
Binary inputs
30001
40000
0
9999
| Modbus Registers
Analog values, variables
40001
60000
0
19999
ReadHoldingRegister
| Reads the value of a single holding register.
- UINT
Address
| Coil Address
- UINT
SetCoil
| Sets the state of a single digital coil.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
| Sets the state of a single digital input.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
| Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
ChangeFrameType
| Default frame type is the type set in the component properties.
- BYTE
Type
| 0 = Modbus RTU / 1 = Modbus ASCII
ReadCoils
| Reads the state of a single digital coil. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
| Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
| Sets the state of a single holding register.
- UINT
Address
| Coil Address
- UINT
Value
| Analogue Value range 0 - 65535
ReadAnalogInput
| Reads the value of a single analogue input.
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
| Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
ReadDigitalInputs
| Reads the state of a single digital input. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
| Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- BYTE
Index
| Range 0-3
- UINT
SetAnalogInput
| Sets the state of a single analogue input.
- UINT
Address
| Coil Address
- UINT
Value
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. Returns 1 if USB is started ok.
- BOOL
USB Properties
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
| USB Major Version Number
Minor Version
| USB Minor Version Number
Return Type
| Specifies the way the receive function indicates a timeout. 8 Bit mode - Timeout is represented by the value 255. 16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Enumeration Timeout
| Specifies if the enumeration (Initialise function) can timeout if taking too long.
USB Driver
Driver Directory
| Directory to save the generated device driver .inf file
Driver Filename
| Filename to give to the generated driver file.
Generate Driver
| Generates a driver file when set to Yes, Automatically jumps back to No when complete.
Modbus Properties
Timeout
| Timeout in milliseconds used to dictate the maximum time to wait in milliseconds between bytes in a packet. Range: 1 - 255
Frame Type
| Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Slave ID Bytes
| Number of bytes used when passing a slave ID, usually 1 but sometimes 2
Slave Address
Reply Delay
| Delay in micro seconds to wait before transmitting a reply
Maintain Stats
| Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Simulation Properties
| A text label to appear on the Modbus panel object.
COM Port
| Hardware COM port to communicate with any connected USB serial devices or any other virtual COM ports.
Modbus Coils - Single bit values
Starting Address
| Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Digital Inputs - Single bit values
Starting Address
| Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Analog Inputs - 16-bit values
Starting Address
| Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Holding Registers - 16-bit values
Starting Address
| Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
ReadHoldingRegister
- UINT
Address
| Coil Address
- UINT
SetCoil
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ChangeFrameType
- BYTE
Type
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
| Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
- BYTE
Index
| Range 0-3
- UINT
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
- BOOL
USB Properties
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
Minor Version
Return Type
Enumeration Timeout
USB Driver
Driver Directory
Driver Filename
Generate Driver
Modbus Properties
Timeout
Frame Type
Receive Buffer Size
Slave ID Bytes
Slave Address
Reply Delay
Maintain Stats
COM Port
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
ReadHoldingRegister
- UINT
Address
| Coil Address
- UINT
SetCoil
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ChangeFrameType
- BYTE
Type
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
| Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
- BYTE
Index
| Range 0-3
- UINT
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
- BOOL
USB Properties
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
Minor Version
Return Type
Enumeration Timeout
USB Driver
Driver Directory
Driver Filename
Generate Driver
Modbus Properties
Timeout
Frame Type
Receive Buffer Size
Slave ID Bytes
Slave Address
Reply Delay
Maintain Stats
COM Port
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
