Component: SCADA (Dummy) (SCADA Slaves)
| Category | SCADA Slaves |
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
|   | I2CInitialise |
| Initialsie the I2C module ready for communications | |
|  - VOID | Return |
|   | IOGetInputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | Return |
|   | I2CRestart |
| Put the I2C Module into Restart mode | |
|  - VOID | Return |
|   | I2CStart |
| Put the I2C Module into Start mode | |
|  - VOID | Return |
|   | SPITransfer |
| Transfer a byte using the SPI bus | |
|  - BYTE | DataOut |
|  - BYTE | Return |
|   | I2CReceive |
| Receive a byte using the I2C bus | |
|  - BOOL | Last |
|  - BYTE | Return |
|   | I2CStop |
| Put the I2C Module into Stop mode | |
|  - VOID | Return |
|   | SPIPrescaler |
| Modify the speed of the SPI bus | |
|  - BYTE | Prescaler |
| Range: 0-2 | |
|  - VOID | Return |
|   | IOSetOutputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | State |
| Range: 0-1 | |
|  - VOID | Return |
|   | SPIInitialise |
|  - VOID | Return |
|   | I2CSend |
|  - BYTE | DataOut |
|  - BOOL | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | I2CInitialise |
|  - VOID | Return |
|   | IOGetInputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | Return |
|   | I2CRestart |
|  - VOID | Return |
|   | I2CStart |
|  - VOID | Return |
|   | SPITransfer |
|  - BYTE | DataOut |
|  - BYTE | Return |
|   | I2CReceive |
|  - BOOL | Last |
|  - BYTE | Return |
|   | I2CStop |
|  - VOID | Return |
|   | SPIPrescaler |
| Range: 0-2 | |
|  - VOID | Return |
|   | IOSetOutputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | State |
| Range: 0-1 | |
|  - VOID | Return |
|   | SPIInitialise |
|  - VOID | Return |
|   | I2CSend |
|  - BYTE | DataOut |
|  - BOOL | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | I2CInitialise |
|  - VOID | Return |
|   | IOGetInputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | Return |
|   | I2CRestart |
|  - VOID | Return |
|   | I2CStart |
|  - VOID | Return |
|   | SPITransfer |
|  - BYTE | DataOut |
|  - BYTE | Return |
|   | I2CReceive |
|  - BOOL | Last |
|  - BYTE | Return |
|   | I2CStop |
|  - VOID | Return |
|   | SPIPrescaler |
| Range: 0-2 | |
|  - VOID | Return |
|   | IOSetOutputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | State |
| Range: 0-1 | |
|  - VOID | Return |
|   | SPIInitialise |
|  - VOID | Return |
|   | I2CSend |
|  - BYTE | DataOut |
|  - BOOL | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
