Component: SPI Master (EB013) (E-blocks 1)
Author | Matrix TSL |
Version | 2.0 |
Category | E-blocks 1 |
SPI Master component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in. If the hardware SPI pins are in use or more SPI channels are required then there is also a software mode available. Has additional functions to work with the E-blocks EB013 SPI hardware.
Please click here to download the component source project: FC_Comp_Source_SPI_Legacy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SPI_Legacy.fcfx
SendString |
Sends a string of bytes to the SPI bus | |
Str |
Return |
GetString |
Attempts to read a string of bytes from the SPI bus. | |
NumBytes |
Ch |
Return |
DACSendChar |
Send a byte to the digital to analogue converter (DAC) on the EB013 SPI E-block. | |
Data |
Data byte to output using the DAC | |
Return |
SendChar |
General purpose SPI send byte macro | |
Char |
Return |
NVMGetChar |
Reads a byte from the non-volatile memory device on the EB013 SPI E-block. | |
Address |
NVM Address to read data from | |
Return |
EnableFram |
Enable the SPI RAM chip on the EB013 SPI E-block. | |
Return |
FramOutput |
Send a value to the RAM on the EB013 SPI E-block. | |
Char |
Return |
DisableFram |
Disable the SPI RAM chip on the EB013 SPI E-block. | |
Return |
GetChar |
General purpose SPI get byte macro | |
Return |
UnInitialise |
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O. | |
Return |
Initialise |
Activates the SPI peripheral and claims control over the I/O pins. | |
Return |
SendString |
Str |
Return |
GetString |
NumBytes |
Ch |
Return |
DACSendChar |
Data |
Return |
SendChar |
Char |
Return |
NVMGetChar |
Address |
Return |
EnableFram |
Return |
FramOutput |
Char |
Return |
DisableFram |
Return |
GetChar |
Return |
UnInitialise |
Return |
Initialise |
Return |
SendString |
Str |
Return |
GetString |
NumBytes |
Ch |
Return |
DACSendChar |
Data |
Return |
SendChar |
Char |
Return |
NVMGetChar |
Address |
Return |
EnableFram |
Return |
FramOutput |
Char |
Return |
DisableFram |
Return |
GetChar |
Return |
UnInitialise |
Return |
Initialise |
Return |
