Component: UART (CAL) (Misc)
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.2
Category Misc
UART component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Please click here to download the component source project: FC_Comp_Source_UART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART.fcfx
Fc9-comp-macro.png ControlPin
Allows direct control over the TX and RTS pins Also allows for reading of the state of the RX and CTS pins. Only available when the UART is uninitialised.
Fc9-u8-icon.png - BYTE Pin
0=TX, 1=RX, 2=RTS, 3=CTS
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png SendString
Transmits a string of bytes via the UART peripheral
Data String to transmit
Fc9-comp-macro.png UpdateBaud
Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
Fc9-u8-icon.png - BYTE new_baud
Fc9-comp-macro.png TestProperty
A simple macro to allow us to test the value of a single property during runtime.
Fc9-u8-icon.png - BYTE Property
0=UseTX, 1=UseRX, 2=UseFlowControl
Fc9-comp-macro.png SendNumber
Transmits a numeric value as an ASCII string
Fc9-s32-icon.png - LONG Number
Numeric value to send
Fc9-comp-macro.png GetValue
Get Value of Named property
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png Prv_SimShowWaveform
Fc9-u8-icon.png - BYTE TXRX
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png Receive
Receive a Character
Fc9-u8-icon.png - BYTE Timeout
Period to wait for the character to be received
Fc9-s16-icon.png - INT Return
Send the Character
Fc9-u16-icon.png - UINT Char
The Character to send
Fc9-comp-macro.png SendByteArray
Transmits an array of bytes via the UART peripheral
Fc9-u8-icon.png - BYTE Data
Data to transmit
Fc9-u8-icon.png - BYTE NumBytes
Number of bytes to send from the array
Fc9-comp-macro.png Init
Initialize the component with the specified properties
Fc9-comp-macro.png Delay
Software UART Bit Delay
Fc9-comp-macro.png SetValue
set Value of Named property
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png GetList
Gets Named property List
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Maximum number of bytes to try and receive
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-type-7-icon.png Component Enable
A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
Fc9-type-16-icon.png Channel
Fc9-conn-icon.png Transmit
Fc9-type-7-icon.png Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png TX
Fc9-conn-icon.png Receive
Fc9-type-7-icon.png Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png RX
Fc9-conn-icon.png Flow Control
Fc9-type-16-icon.png Use Flow Control
Fc9-conn-icon.png Options
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Data Bits
Number of data bits
Fc9-type-16-icon.png Return
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Fc9-type-16-icon.png Echo
Automatically echoes back any received data when enabled by re-transmitting the received byte.
Fc9-type-16-icon.png Interrupt
Automatic receive interrupt mode enable or disable. Used on components such as the GSM or GPS where data can come in at any time. Software channel is disabled when interrupt is enabled, for interrupt with a software channel use an I/O edge triggered interrupt.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
Receive a Character
Send the Character
Data to transmit
Number of data bits
Receive a Character
Send the Character
Data to transmit
Number of data bits
