Component: WLAN (ESP32) (Comms: Networking)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.4 |
Category | Comms: Networking |
WLAN (ESP32) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32.fcfx
ReadIPString | |
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1" | |
- STRING | Return |
SocketConnect | |
- STRING | Address |
- UINT | Port |
- BYTE | Return |
SocketListen | |
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail | |
- UINT | Port |
- BYTE | Return |
ReadSSIDFromScan | |
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
- BYTE | Index |
SSID Index | |
- STRING | Return |
SocketWrite | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
Disconnect | |
Attempts to disconnect from the SSID. | |
- BYTE | Return |
SocketOpen | |
Returns 1 if socket sucessfully opened | |
- BYTE | Return |
SocketClose | |
- VOID | Return |
Uninitialise | |
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not | |
- BYTE | Return |
AcceptOpen | |
Returns 1 if there is an incoming connection on the listening port | |
- BYTE | Return |
SocketRead | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
AcceptClose | |
Close the socket associated with the Accepted incoming connection | |
- VOID | Return |
Initialise | |
Initialise the WiFi system Returns 1 if successful Returns 0 if not | |
- BYTE | Return |
Properties | |
Verbose Debug | |
Simulation | |
Network Interface | |
List of network interfaces connected to the PC. Sets which interface we are communicating via. | |
Console Data | |
Generate Console Data |
ReadIPString | |
- STRING | Return |
SocketConnect | |
- UINT | Port |
- BYTE | Return |
SocketListen | |
- UINT | Port |
- BYTE | Return |
- BYTE | Index |
SSID Index | |
- STRING | Return |
SocketWrite | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
Disconnect | |
- BYTE | Return |
SocketOpen | |
- BYTE | Return |
SocketClose | |
- VOID | Return |
Uninitialise | |
- BYTE | Return |
AcceptOpen | |
- BYTE | Return |
SocketRead | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
AcceptClose | |
- VOID | Return |
Initialise | |
- BYTE | Return |
Properties | |
Verbose Debug | |
Simulation | |
Console Data | |
ReadIPString | |
- STRING | Return |
SocketConnect | |
- UINT | Port |
- BYTE | Return |
SocketListen | |
- UINT | Port |
- BYTE | Return |
- BYTE | Index |
SSID Index | |
- STRING | Return |
SocketWrite | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
Disconnect | |
- BYTE | Return |
SocketOpen | |
- BYTE | Return |
SocketClose | |
- VOID | Return |
Uninitialise | |
- BYTE | Return |
AcceptOpen | |
- BYTE | Return |
SocketRead | |
- STRING | Buffer |
- UINT | Size |
- UINT | Return |
AcceptClose | |
- VOID | Return |
Initialise | |
- BYTE | Return |
Properties | |
Verbose Debug | |
Simulation | |
Console Data | |
