| Author
Matrix Ltd
| Version
1.3
| Category
Analog Input
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for  wrapping with a new ADC style component.
Please click here to download the component source project: FC_Comp_Source_adc_Base_2dgdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base_2dgdi.fcfx
RawSampleInt
| Background call to read the ADC at full bit depth Call Enable() first
  - UINT
RawAverageByte
| Background call to read the ADC as a byte average sample over time Call Enable() before this
  - BYTE
NumSamples
  - BYTE
DelayUs
| Number of micro seconds in between taking each sample
  - BYTE
GetSampleBits
| Gets the number of bits per sample
  - BYTE
GetString
| Reads the ADC as a direct voltage and returns as a string
  - STRING
GetAverageByte
| Function call to read the ADC as a byte average sample over time
  - BYTE
NumSamples
  - BYTE
DelayUs
  - BYTE
RawAverageInt
| Background call to read the ADC as a full width average sample over time Call Enable() before this
  - BYTE
NumSamples
  - BYTE
DelayUs
  - INT
GetSpeedFilter
| Gets the Conversion speed filter string Use in Component.Property.SetFilter()
  - STRING
GetAverageInt
| Function call to read the ADC as a full width average sample over time
  - BYTE
NumSamples
  - BYTE
DelayUs
  - UINT
SetProperties
| Set the VRef options and voltage, ConvSpeed and AcqTime for the ADC component.
  - INT
VRef10Ms
| Voltage Reference x10 mV - Default 500 = 5V
  - BOOL
VRefOpt
| External VRef 0=Disabled, 1=Enabled
  - INT
ConvSpdOpt
| Conversion Speed Setting - Refer to numbered list
  - INT
Aquisitions
| Aquisition time in micro seconds to precharge before sampling
GetVoltage
  - FLOAT
RawEnable
| Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
SetChannel
| Sets the channel ID for the component
  - INT
ChannelId
| Chaannel starting at 0, -1 is unconnected
RawSampleByte
| Background call to read the ADC as a byte Call Enable() before this
  - BYTE
GetInt
| Blocking call to read the ADC at full bit depth
  - UINT
RawDisable
| Disables the previously enabled ADC channel and converts back to digital mode.
GetByte
| Blocking call to read the ADC as a byte
  - BYTE
| Analogue Input Channel - Which pin is the analogue input connected to?
Settings
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Bit Depth
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023  12 bit = ADC range 0 - 4095
RawSampleInt
  - UINT
RawAverageByte
  - BYTE
NumSamples
  - BYTE
DelayUs
  - BYTE
GetSampleBits
  - BYTE
GetString
  - STRING
GetAverageByte
  - BYTE
NumSamples
  - BYTE
DelayUs
  - BYTE
RawAverageInt
  - BYTE
NumSamples
  - BYTE
DelayUs
  - INT
GetSpeedFilter
  - STRING
GetAverageInt
  - BYTE
NumSamples
  - BYTE
DelayUs
  - UINT
SetProperties
  - INT
VRef10Ms
  - BOOL
VRefOpt
  - INT
ConvSpdOpt
  - INT
Aquisitions
GetVoltage
  - FLOAT
RawEnable
SetChannel
  - INT
ChannelId
RawSampleByte
  - BYTE
GetInt
  - UINT
RawDisable
GetByte
  - BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
RawSampleInt
  - UINT
RawAverageByte
  - BYTE
NumSamples
  - BYTE
DelayUs
  - BYTE
GetSampleBits
  - BYTE
GetString
  - STRING
GetAverageByte
  - BYTE
NumSamples
  - BYTE
DelayUs
  - BYTE
RawAverageInt
  - BYTE
NumSamples
  - BYTE
DelayUs
  - INT
GetSpeedFilter
  - STRING
GetAverageInt
  - BYTE
NumSamples
  - BYTE
DelayUs
  - UINT
SetProperties
  - INT
VRef10Ms
  - BOOL
VRefOpt
  - INT
ConvSpdOpt
  - INT
Aquisitions
GetVoltage
  - FLOAT
RawEnable
SetChannel
  - INT
ChannelId
RawSampleByte
  - BYTE
GetInt
  - UINT
RawDisable
GetByte
  - BYTE
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
