Author
Matrix Ltd
Version
3.0
Category
Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
Auto Detect Example
ReceiveByte
Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
- UINT
Timeout
Time to wait for incoming data in milliseconds
- UINT
ConfigureConsole
- BYTE
Status
SendString
Sends an string of characters to the COM port.
- STRING
Data
Data byte array to send
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT
Data
Array to store the incoming data
- BYTE
NumValues
Maximum number of values to try and receive
- BOOL
MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
Max amount of time in ms to wait between bytes
- BYTE
ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
Max time in ms to wait in between bytes
- BOOL
IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
- LONG
SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
- UINT
Value
- BOOL
MSBfirst
SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
- UINT
Data
Data to transmit
- BYTE
NumValues
Number of 16-bit values to send from the array
- BOOL
MSBfirst
SendNumber
Sends out a number as an ASCII String from the UART interface.
- LONG
Number
ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- FLOAT
SendByte
Sends a single byte to be sent out via the COM port.
- BYTE
Data
SetDTRState
Allows the DTR signal to be enabled or disabled.
- BYTE
State
A value of 0 disables the DTR, 1 or above willl enable the DTR.
ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
- STRING
HWID
Example: "VID_12BF&PID_0101"
- BYTE
GetConsoleHandle
- HANDLE
SendByteArray
Sends an array of bytes to the COM port.
- BYTE
Data
- UINT
Length
Number of bytes to send
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
- BOOL
IgnoreData
- FLOAT
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT
Number
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
- BOOL
Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
- BOOL
IgnoreData
- BOOL
Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
- BOOL
MSBfirst
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
- FLOAT
Value
- BOOL
MSBfirst
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
Max number of bytes to try and read
- UINT
Timeout
- UINT
ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
Timeout Value
Value to specify what is returned when no incoming receive data is present.
Auto Close
Auto close the port on Sim stop event
New Line Format
ReceiveByte
- UINT
Timeout
- UINT
ConfigureConsole
- BYTE
Status
SendString
- STRING
Data
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
ReceiveNumber
- BYTE
Timeout
- BOOL
IgnoreData
- LONG
SendBinary16Bit
- UINT
Value
- BOOL
MSBfirst
SendINTArray
- UINT
Data
Data to transmit
- BYTE
NumValues
- BOOL
MSBfirst
SendNumber
- LONG
Number
ReceiveBinary32Bit
- BOOL
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
ReceiveBinaryFloat
- BOOL
MSBfirst
- BYTE
Timeout
- FLOAT
SendByte
- BYTE
Data
SetDTRState
- BYTE
State
ScanForDeviceID
- STRING
HWID
- BYTE
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
- UINT
Length
ReceiveBinary16Bit
- BOOL
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
- BYTE
Timeout
- BOOL
IgnoreData
- FLOAT
SendFloat
- FLOAT
Number
SendHexNumber
- ULONG
Number
- BYTE
NumChars
- BOOL
Prefix
SetFlowControl
- BYTE
State
OpenPort
ReceiveHexNumber
- BYTE
Timeout
- BOOL
IgnoreData
- BOOL
Prefix
- ULONG
SetProp
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
- ULONG
Value
- BOOL
MSBfirst
SendBinaryFloat
- FLOAT
Value
- BOOL
MSBfirst
GetProp
- STRING
PropName
- STRING
ReceiveByteArray
- BYTE
Data
- UINT
MaxLength
- UINT
Timeout
- UINT
ReceiveString
- UINT
Timeout
- UINT
MaxLength
- STRING
COM Port
Refresh COM Ports
Baud
Timeout Value
Auto Close
New Line Format
ReceiveByte
- UINT
Timeout
- UINT
ConfigureConsole
- BYTE
Status
SendString
- STRING
Data
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
ReceiveNumber
- BYTE
Timeout
- BOOL
IgnoreData
- LONG
SendBinary16Bit
- UINT
Value
- BOOL
MSBfirst
SendINTArray
- UINT
Data
Data to transmit
- BYTE
NumValues
- BOOL
MSBfirst
SendNumber
- LONG
Number
ReceiveBinary32Bit
- BOOL
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
ReceiveBinaryFloat
- BOOL
MSBfirst
- BYTE
Timeout
- FLOAT
SendByte
- BYTE
Data
SetDTRState
- BYTE
State
ScanForDeviceID
- STRING
HWID
- BYTE
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
- UINT
Length
ReceiveBinary16Bit
- BOOL
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
- BYTE
Timeout
- BOOL
IgnoreData
- FLOAT
SendFloat
- FLOAT
Number
SendHexNumber
- ULONG
Number
- BYTE
NumChars
- BOOL
Prefix
SetFlowControl
- BYTE
State
OpenPort
ReceiveHexNumber
- BYTE
Timeout
- BOOL
IgnoreData
- BOOL
Prefix
- ULONG
SetProp
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
- ULONG
Value
- BOOL
MSBfirst
SendBinaryFloat
- FLOAT
Value
- BOOL
MSBfirst
GetProp
- STRING
PropName
- STRING
ReceiveByteArray
- BYTE
Data
- UINT
MaxLength
- UINT
Timeout
- UINT
ReceiveString
- UINT
Timeout
- UINT
MaxLength
- STRING
COM Port
Refresh COM Ports
Baud
Timeout Value
Auto Close
New Line Format
ReceiveByte
- UINT
Timeout
- UINT
ConfigureConsole
- BYTE
Status
SendString
- STRING
Data
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
ReceiveNumber
- BYTE
Timeout
- BOOL
IgnoreData
- LONG
SendBinary16Bit
- UINT
Value
- BOOL
MSBfirst
SendINTArray
- UINT
Data
Data to transmit
- BYTE
NumValues
- BOOL
MSBfirst
SendNumber
- LONG
Number
ReceiveBinary32Bit
- BOOL
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
ReceiveBinaryFloat
- BOOL
MSBfirst
- BYTE
Timeout
- FLOAT
SendByte
- BYTE
Data
SetDTRState
- BYTE
State
ScanForDeviceID
- STRING
HWID
- BYTE
GetConsoleHandle
- HANDLE
SendByteArray
- BYTE
Data
- UINT
Length
ReceiveBinary16Bit
- BOOL
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
- BYTE
Timeout
- BOOL
IgnoreData
- FLOAT
SendFloat
- FLOAT
Number
SendHexNumber
- ULONG
Number
- BYTE
NumChars
- BOOL
Prefix
SetFlowControl
- BYTE
State
OpenPort
ReceiveHexNumber
- BYTE
Timeout
- BOOL
IgnoreData
- BOOL
Prefix
- ULONG
SetProp
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
- ULONG
Value
- BOOL
MSBfirst
SendBinaryFloat
- FLOAT
Value
- BOOL
MSBfirst
GetProp
- STRING
PropName
- STRING
ReceiveByteArray
- BYTE
Data
- UINT
MaxLength
- UINT
Timeout
- UINT
ReceiveString
- UINT
Timeout
- UINT
MaxLength
- STRING
COM Port
Refresh COM Ports
Baud
Timeout Value
Auto Close
New Line Format
