Component: CSV Read/Write (File)
| Category | File |
CSV Read/Write component
A component to simplify the task of creating and dumping data to a CSV file that can be loaded into Microcoft Excel or LibreOffice Math to create nice charts and graphs. Requires one of the File components to provide access to the file system.
Please click here to download the component source project: FC_Comp_Source_CSV_Writer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CSV_Writer.fcfx
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
CSV Component used with Embedded -> File SD component:
CSV Test
CSV Component used with Embedded -> File RPI component:
CSV Test RPI
CSV Component used with App Developer -> File component:
CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
| CloseFile | |
| Closes the file and finishes off any pending writes ready for use in an external application. | |
| SequentialReadString | |
| Reads the contents of a cell as a string. Automatically moved to the next data cell after a read. | |
| AddString | |
| Adds a string to the CSV followed by a comma. This will form a single column of data in the CSV file. | |
| data | |
| ReadAsString | |
| Reads the contents of a cell as a string | |
| Column | |
| Row | |
| SequentialReadNumber | |
| Reads the contents of a cell as a number. Automatically moved to the next data cell after a read. | |
| AddNumber | |
| Adds a number to the CSV followed by a comma. This will form a single column of data in the CSV file. | |
| data | |
| ReadAsNumber | |
| Reads the contents of a cell as a number. | |
| Column | |
| Row | |
| SetSequentialIndex | |
| Sets the index for sequential reads. Index is automatically reset to 0 after a file open. | |
| Index | |
| NextRow | |
| Move to the next row in the file | |
| Properties | |
| LinkTo | |
| CloseFile | |
| AddString | |
| data | |
| ReadAsString | |
| Column | |
| Row | |
| AddNumber | |
| data | |
| ReadAsNumber | |
| Column | |
| Row | |
| Index | |
| NextRow | |
| Properties | |
| LinkTo | |
| CloseFile | |
| AddString | |
| data | |
| ReadAsString | |
| Column | |
| Row | |
| AddNumber | |
| data | |
| ReadAsNumber | |
| Column | |
| Row | |
| Index | |
| NextRow | |
| Properties | |
| LinkTo | |
| CloseFile | |
| AddString | |
| data | |
| ReadAsString | |
| Column | |
| Row | |
| AddNumber | |
| data | |
| ReadAsNumber | |
| Column | |
| Row | |
| Index | |
| NextRow | |
| Properties | |
| LinkTo | |
