Component: Clone Matrix (Misc)
Revision as of 09:52, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Misc
Clone Matrix component
Takes a single object and produces a three dimensional array of evenly spaced clones. Inidividual items in the array can be found from their position and individually modified after the array has been created.
Please click here to download the component source project: FC_Comp_Source_Clone_Matrix.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Clone_Matrix.fcfx
The clone matrix can be used to create multiple panel objects based on the geometry of a single object.
Here we have a sphere object on the panel
By adding the Clone Matrix component and configuring the component properties we generate the cloned objects. If we need to re-clone the objects at any time then we can simply refresh the properties of the clone matrix component.
Here is the final output result on the panel.
Once the matrix is generated you can control the properties of the individual items.
Example showing how to collect the handle of one of the clones to allow it's individual characteristics to be edited. For example in creating the simulation for a LED Cube or Array. CloneMatrix
GetHandleFor
Gets the handle of the Nth object in the matrix. Index counts in the order along X, then Y, then Z.
- UINT Index
Index of the object to get a handle for.
- HANDLE Return
GetHandleAt
Gets the handle of the object at position [X, Y, Z] in the matrix.
- BYTE IndexX
- BYTE IndexY
- BYTE IndexZ
- HANDLE Return
Update
Updates the matrix to reflect any changes to the source object. NB) This will discard any changes made to individual objects within the array.
Target Object
Chooses the original panel object to be cloned into the matrix.
Hide Target
Whether the original object should be hidden once copied into the array. The object will be revealed automatically if the target object is changed or disconnected.
X Axis
Count
Number of columns of clones along the X-axis.
Spacing
Distance between columns along the X-axis.
Y Axis
Count
Number of rows of clones along the Y-axis.
Spacing
Distance between rows along the Y-axis.
Z Axis
Count
Number of layers of clones along the Z-axis.
Spacing
Distance between layers along the Z-axis.
GetHandleFor
- UINT Index
- HANDLE Return
GetHandleAt
- BYTE IndexX
- BYTE IndexY
- BYTE IndexZ
- HANDLE Return
Update
Target Object
Hide Target
X Axis
Count
Spacing
Y Axis
Count
Spacing
Z Axis
Count
Spacing
GetHandleFor
- UINT Index
- HANDLE Return
GetHandleAt
- BYTE IndexX
- BYTE IndexY
- BYTE IndexZ
- HANDLE Return
Update
Target Object
Hide Target
X Axis
Count
Spacing
Y Axis
Count
Spacing
Z Axis
Count
Spacing
GetHandleFor
- UINT Index
- HANDLE Return
GetHandleAt
- BYTE IndexX
- BYTE IndexY
- BYTE IndexZ
- HANDLE Return
Update
Target Object
Hide Target
X Axis
Count
Spacing
Y Axis
Count
Spacing
Z Axis
Count
Spacing
