Component: Current Sensor (ACS7xx) (Electrical)
Revision as of 09:52, 27 January 2023 by Wiki bot (talk | contribs)
Author medelec35
Category Electrical
Current Sensor (ACS7xx) component
ACS7XX range of +/- 5, 20, 30, 50, 100, 150 & 200A current sensors
Please click here to download the component source project: FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Simple example showing how to use the simulation dial components as a meter display for use in monitoring type applications. Meters
Current
Current reading in amps
- FLOAT Return
VoltgeADC
Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
- FLOAT Return
Device
Type
VDD
Offset current adjust (Amps)
Offset current adjusts the curent output when comparing to a current monitor. For example current from the componet shows 2.0 Amps and curent monitor shows 1.5 Amps. For the current offset enter -0.5
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT Return
VoltgeADC
- FLOAT Return
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT Return
VoltgeADC
- FLOAT Return
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT Return
VoltgeADC
- FLOAT Return
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
