Component: DALI Slave (Comms: System)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here to download the component source project: FC_Comp_Source_DALI_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Slave.fcfx
Fc9-comp-macro.png ReceiveForwardFrame
Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply
Fc9-comp-macro.png CheckForIndividualAddress
Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png CollectDataByte
Returns the data byte from a 16-bit data packet
Fc9-comp-macro.png CheckForGroupAddress
Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match
Fc9-comp-macro.png CollectPacketType
Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command
Fc9-comp-macro.png TransmitBackwardFrame
Send out a 8-bit frame consisting of a data byte.
Fc9-u8-icon.png - BYTE Data
Data Byte
Fc9-comp-macro.png Initialise
Configures the UART serial interface.
Fc9-conn-icon.png Serial Properties
Fc9-type-5-icon.png TX Pin
Fc9-type-5-icon.png RX Pin
Fc9-conn-icon.png DALI Slave Properties
Fc9-type-21-icon.png Individual Address
Address ranging from 0-63
Fc9-type-21-icon.png Group Address
Address ranging from 0-15
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Data Byte
Data Byte
Data Byte
