Component: Scale (DSP Operators)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category DSP Operators
Scale component
Allows the values in a single buffer to be scaled uniformly. Functions include: Multiply, Divide, LeftShift, RightShift, Float Multiply, Float Divide
Please click here to download the component source project: FC_Comp_Source_DSP_Scale.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Scale.fcfx
Here is an example which demonstrates variable scaling based on an analogue input.
FC6 Icon.png Scale
Here are the traces as seen on the data recorder window.
The RightShift macro is a very efficient means of performing a division but only for values which are a power of 2.
The LeftShift macro is a very efficient means of performing a multiplication but only for values which are a power of 2.
LeftShift(1) = Multiply by 2 / RightShift(1) = Divide by 2
LeftShift(2) = Multiply by 4 / RightShift(2) = Divide by 4
LeftShift(3) = Multiply by 8 / RightShift(3) = Divide by 8
LeftShift(4) = Multiply by 16 / RightShift(4) = Divide by 16
Fc9-comp-macro.png SetScalerFloat
Sets the Float scaler to be used when calling the calculate function.
Fc9-f32-icon.png - FLOAT Scaler
Fc9-comp-macro.png SetScalerInteger
Sets the Integer scaler to be used when calling the calculate function.
Fc9-s16-icon.png - INT Scaler
Fc9-comp-macro.png Calculate
Performs the selected scaling on a value from the input buffer and passes to the output buffer.
Fc9-comp-macro.png CalculateArray
Performs the selected scaling on an entire buffer.
Fc9-type-16-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Direction
Sets the data direction flow of the component
Fc9-conn-icon.png Scaling
Fc9-type-16-icon.png Scale Type
Defines the type of calculation performed on the input buffer to obtain the output value. A left shift is essentially an optimised multiply with the multiplier being the 2^scaler A right shift is essentially an optimised divide with the divider being the 2^scaler
Fc9-type-7-icon.png Rollover
Allow the output buffer to rollover. For example 128 * 2 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled. With rollover disabled the output would be set to 255 which is the max representable value.
Fc9-type-14-icon.png Initial Integer Scaler
