| Author
Matrix Ltd
| Version
1.1
| Category
Switch (Push, Dashboard) component
Simple momentary push-button using the Matrix dashboard theme.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Button.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Button.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
Connection
| Chip pin to which the button is connected.
Polarity
| Whether the pin is taken high or low by pressing the button.
Debounce (ms)
| Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state using the component macros. Chip pins are NOT debounced!
Text
| Text for the label displayed below the button.
Font
| Font to use for the text label beneath the buttion.
Label Color
| Color for the test of the label shown beneath the button.
Bezel Color
| Color for the bezel surrounding the button.
Button Color
| Color of the moving part of the button.
Operation
| Latching = Mouse click to turn on, click again to turn off. Momentary = Click to turn on, release to turn off.
Connection
Polarity
Debounce (ms)
Text
Font
Label Color
Bezel Color
Button Color
Operation
Connection
Polarity
Debounce (ms)
Text
Font
Label Color
Bezel Color
Button Color
Operation
Connection
Polarity
Debounce (ms)
Text
Font
Label Color
Bezel Color
Button Color
Operation
