Component: Dashboard Text (Runtime Tools)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Runtime Tools
Dashboard Text component
A simulation only text box that can be used to display text and numbers.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Text.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Text.fcfx
Clear
Remove all text from the display.
PrintString
Add the given text to the display immediately after the most recent character and without beginning a new line.
- STRING Text
The text to add to the display.
Write the given number to the display. It will be placed immediately after the last character on the display without beginning a new line.
- FLOAT Number
- BYTE Places
PrintLine
DIsplay the given string on a new line. If the display is full, it will scroll upwards to make space.
- STRING Text
Text
Start Text
Set the text that will appear when the component is initialised.
Lines
Set the number of lines of text that the display will show. Lines will scroll off the top of the box once the display is full.
Font
Choose the font for the text. Any font installed on your PC can be used. If your file is opened on another computer which does not have the specified font, an alternative will automatically be chosen.
Horizontal Align
Choose whether text will be aligned to the left, right or centre of the box width.
Vertical Align
Choose whether text will be aligned wih the top, bottom or middle of the box height.
Colors
Text
Color for the text characters.
Background
Color for the box background.
Bezel
Color for the bezel (3D border)
Bezel
Thickness
The thickness of the bezel (3D border). This thickness will be maintained even when the component is resized.
Margin
Set the margin size. This is used to insert a small blank space to the left and right of the text, so that characters are not placed right up against the bezel.
Clear
PrintString
- STRING Text
- FLOAT Number
- BYTE Places
PrintLine
- STRING Text
Text
Start Text
Lines
Font
Horizontal Align
Vertical Align
Colors
Text
Background
Bezel
Bezel
Thickness
Margin
Clear
PrintString
- STRING Text
- FLOAT Number
- BYTE Places
PrintLine
- STRING Text
Text
Start Text
Lines
Font
Horizontal Align
Vertical Align
Colors
Text
Background
Bezel
Bezel
Thickness
Margin
Clear
PrintString
- STRING Text
- FLOAT Number
- BYTE Places
PrintLine
- STRING Text
Text
Start Text
Lines
Font
Horizontal Align
Vertical Align
Colors
Text
Background
Bezel
Bezel
Thickness
Margin
