Component: GameCode (Misc Circuit)
Author | Jef De Bruyne |
Version | 1.0 |
Category | Misc Circuit |
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
Please click here to download the component source project: FC_Comp_Source_GameCode_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GameCode_Master.fcfx
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
PwrLedSet |
Control the PWR LED. 0 = red + green 1 = red 2 = green | |
Value |
0 = red + green, 1 = red, 2 = green | |
Return |
EEStoreValue |
Saves a value to none volitile memory | |
Address |
Address to write to, Range: 0-255 | |
Value |
Value to store, Range: 0-255 | |
Return |
MP3GetStatus |
Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped | |
Return |
MP3PausePlayResetStop |
Allows the current playing track to be paused, restarted or stopped. | |
Mode |
0=Pause, 1=Play, 2=Reset, 3=Stop | |
Return |
MP3SendCommand |
Send commands to MP3 module. Check datasheet for info. | |
Command |
Para1 |
Para2 |
Return |
EEReadValue |
Retreives a value from none volitile memory | |
Address |
Return |
DisplayWriteNumber |
Show a number ranging from 000 to 999 on the display. Number is printed vertically. | |
Value |
Enter a number from 0 to 999. | |
Return |
DisplayClear |
Clear the display. | |
Return |
BatteryRead |
Read and return the voltage level of the battery in millivolt. | |
Return |
LedsWrite |
Set the button-leds. MSB = leftmost led LSB = rightmost led | |
Value |
MSB = leftmost dot, LSB = rightmost dot | |
Return |
MP3SetVolume |
Sets the volume level for the MP3 module | |
Volume |
Range: 0 (min) - 30 (max) | |
Return |
DisplayBrightness |
Control the brightness of the display. | |
Value |
Enter value from 0 to 15 | |
Return |
Initialise |
Initializes all present hardware and communication. Place this at the very start of your code. | |
Return |
Properties |
LED Colours |
LED On |
LED Off |
Display Colours |
On Colour |
Off Colour |
Background Colour |
PwrLedSet |
Value |
Return |
EEStoreValue |
Address |
Value |
Return |
MP3GetStatus |
Return |
Mode |
Return |
MP3SendCommand |
Command |
Para1 |
Para2 |
Return |
EEReadValue |
Address |
Return |
Value |
Return |
DisplayClear |
Return |
BatteryRead |
Return |
LedsWrite |
Value |
Return |
MP3SetVolume |
Volume |
Return |
DisplayBrightness |
Value |
Return |
Initialise |
Return |
Properties |
LED Colours |
LED On |
LED Off |
Display Colours |
On Colour |
Off Colour |
Background Colour |
PwrLedSet |
Value |
Return |
EEStoreValue |
Address |
Value |
Return |
MP3GetStatus |
Return |
Mode |
Return |
MP3SendCommand |
Command |
Para1 |
Para2 |
Return |
EEReadValue |
Address |
Return |
Value |
Return |
DisplayClear |
Return |
BatteryRead |
Return |
LedsWrite |
Value |
Return |
MP3SetVolume |
Volume |
Return |
DisplayBrightness |
Value |
Return |
Initialise |
Return |
Properties |
LED Colours |
LED On |
LED Off |
Display Colours |
On Colour |
Off Colour |
Background Colour |
PwrLedSet |
Value |
Return |
EEStoreValue |
Address |
Value |
Return |
MP3GetStatus |
Return |
Mode |
Return |
MP3SendCommand |
Command |
Para1 |
Para2 |
Return |
EEReadValue |
Address |
Return |
Value |
Return |
DisplayClear |
Return |
BatteryRead |
Return |
LedsWrite |
Value |
Return |
MP3SetVolume |
Volume |
Return |
DisplayBrightness |
Value |
Return |
Initialise |
Return |
Properties |
LED Colours |
LED On |
LED Off |
Display Colours |
On Colour |
Off Colour |
Background Colour |
