Component: Data Transfer (API UART) ()
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category
Data Transfer (API UART) component
Comms data injector to allow a Serial UART peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical UART.
Please click here to download the component source project: FC_Comp_Source_InjectorSCADAUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAUART.fcfx
InitialiseInjector
- STRING InjectorName
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
- BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
SCADA Slave
BAUD Rate
Sets the data bit rate of the Serial UART. See the SCADA Slave UART Baud macro for valid values,
RS485 Direction Control
Allows an I/O pin to be automatically assigned when transmitting and receiving.
RS485 Properties
RS485 Pin Number
Digital I/O pin number to use for the RS485 data direction pin
TX Pin State
Decides the state of the RS485 data direction pin when transmitting data.
RX Pin State
Decides the state of the RS485 data direction pin when receiving data.
InitialiseInjector
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
- BYTE State
SCADA Slave
BAUD Rate
RS485 Properties
RS485 Pin Number
TX Pin State
RX Pin State
InitialiseInjector
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
- BYTE State
SCADA Slave
BAUD Rate
RS485 Properties
RS485 Pin Number
TX Pin State
RX Pin State
InitialiseInjector
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
ChangeState
- BYTE State
SCADA Slave
BAUD Rate
RS485 Properties
RS485 Pin Number
TX Pin State
RX Pin State
